I Equivalent statements of the weak energy condition
hideelo
Im reading Carroll's Spacetime and Geometry section 4.2 where he claims the following as the weak energy condition:
Given a energy momentum tensor T and a timelike vector t then Tμν tμ tν ≥ 0.
He claims that for a perfect fluid this is equivalent to the statement that ρ ≥ 0 and (ρ+P) ≥ 0. Where ρ is the density and P the pressure
He shows this by first showing that if the timelike vector t was the velocity of the fluid (i.e. we were in the rest frame of the fluid) then the weak energy condition reduces to ρ ≥ 0. So far so good. Then he claims that for a lightlike vector l, Tμν lμ lν ≥ 0 implies that (ρ+P) ≥ 0. I see that. He then says that I should convince myself that these conditions on ρ and P therefore hold for any timelike vectors as a consequnce, I don't see how, can anyone explain it to me?
Consider the following proposition: given any timelike vector ##t^\mu##, we can express any other timelike vector ##v^\mu## as a linear combination of ##t^\mu## and some null vector ##l^\mu## (which might be a different null vector for different ##v^\mu##). Is it true? And if it is, does it help in answering your question?
That's what I thought as well. However, If you think about it it must be wrong. If given some timelike vector tμ any other timelike vector vμ can be written as a sum of tμ and some lightlike vector lμ, flip that statement around and you get that the difference between any two timelike vectors is a lightlike vector, and that's not true
I stated it sloppily. The correct statement is that, given any future-directed timelike vector ##t##, any other future-directed timelike vector ##v## can be expressed as a linear combination, with positive coefficients (positive provided that ##v \neq t##), of ##t## and some future-directed lightlike vector ##l##. The "future directed" part is crucial.
No, because the second timelike vector has a positive coefficient in front of it, and both timelike vectors are future directed. So all you really get by flipping the statement around is that, by subtracting some particular coefficient times a timelike vector ##v## from another timelike vector ##t## (both being future-directed), you can get a lightlike vector. But given ##t## and ##u##, only one particular value for the coefficient will work. So it's much more specific than the statement that the difference between any two timelike vectors is lightlike (which is indeed false); that would amount to claiming that you can choose the coefficient arbitrarily, which is not the case.
To state things concretely: we have
v = a t + b l
where ##t## and ##v## are timelike and ##l## is null, ##a > 0## and ##b > 0##. Then we have
\frac{1}{b} v - \frac{a}{b} t = l
Furthermore, to obtain specific expressions for ##a## and ##b##, we can always choose a local inertial coordinate chart in which ##t = (u, 0, 0, 0)##, where ##u > 0##, and in which ##v = (w, x, 0, 0)##, where ##w > x > 0##. (This amounts to choosing a chart in which ##t## corresponds to the 4-momentum of an observer at rest, and the first spatial direction points along the direction of motion of ##v## with respect to ##t##.) Then, if we write ##l = (k, k, 0, 0)##, where ##k > 0## and ##|k|## can be chosen arbitrarily, we obviously have
v = \frac{w - x}{u} t + \frac{x}{k} l
This can be inverted to express ##l## in terms of ##t## and ##v##, but only with one particular set of coefficients.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
