Err, two questions related to center of gravity and friction
The discussion centers on the concept of gravitational forces acting as parallel forces due to the significant distance from the Earth's center, approximately 6300 km. This distance allows for simplifications in calculations, as the gravitational forces on objects close together can be treated as parallel, despite not being perfectly so. The participants also seek clarification on the relationship between parallel forces and distance. Additionally, there is a request for an explanation regarding the friction of sand, indicating an interest in understanding how these concepts apply to different materials. Overall, the conversation highlights the importance of distance in physics calculations and the nature of gravitational forces.
YenTe
"since the distance of forces(the center of gravity forces) from the gravity are at a very large distance so they are just like parallel forces"
now what do parallel forces have to do with distance or vice versa?
Explain.
and then please explain the friction of sand.
anyone?!
Since the distance to the center of the Earth is very big (around 6300 km), all gravitational forces can be considered acting in parallel directions. For example, imagine two objects on the surface of the Earth resting close to each other, let's say one meter. If you draw a sketch, and if you connect every object with a straight line to the center of the Earth, these lines will not be parallel. But since the distance to the center of the Earth is, as mentioned, very big, these two lines can considered to be parallel, which simplifies calculations, but still keeps them in limits of satisfying accuracy.
