Error Propagation with Log2 Concentration: Fluorescence Measurement
In the discussion on error propagation with log2 concentration in fluorescence measurements, the key point is the importance of consistency in reporting measurements and their associated errors. When calculating error propagation, it is crucial to use the same scale (log2 or linear) as the measurements being reported. The confusion arises when comparing percent differences in linear versus log2 scales, as non-linear functions do not preserve ratios, leading to different results. The forum participants emphasize that understanding the nature of the functions involved is essential for accurate calculations. Overall, maintaining clarity in measurement reporting and calculations is vital for reliable data interpretation.
PhysicsInquirer
Hi there,
I have a quick question to report some numbers on an experiment. I made measurements of fluorescence in a titration of a chemical. The titrations were 1:2 serial dilutions so I report each fluorescence as a function of the log2 concentration:
concentration chemical x: 1 , 0.5, 0.25
reported concentration chemical x (log2): 0, -1,-2
fluorescence measurement: 5, 10, 25
I’m interested in reporting the concentrations of a chemical that lead to a specific fluorescence. So, let’s say I want to report when the fluorescence reaches 10, in this case that would be -1.
So keeping that in mind: When I make error propagation calculations should I use the log2 or the linear measurements?
Sometimes I need to interpolate to get the reported concentrations. For instance, when I want to get the concentration that leads to fluorescence 15. Does that change anything for the calculations?
Mathematics news on Phys.org
Welcome to the forum.
It depends on context.
Generically, you should report what you measured, and the error in your measurement. If you measured x then you should report x and the error in x. If you measured log2 of x, then you should report log2 of x and the error in log2 of x.
If you are calculating something based on the concentration, then if you are using x in the calculation you should use the uncertainty in x. If you are using log2 of x in the calculation, then you should use the error in log2 of x.
Does this help?
Thanks for your reply. So if I understand correctly, as long as I don't mix logs and linear measurements I should be all set for what I'm reporting.
I'm still a confused though when I want to compute different metrics, like the error propagation or the percent difference ( i.e. , difference/average)
So for instance if I have the following replicate measurements and I want to compute the percent difference:
Replicate 1: 0.0625
Replicate 2: 0.0725
Replicate 1 in log2: -4
Replicate 2 in log2: -3.7859Percent difference in linear: (0.0725-0.0625) / ( (0.0725+0.0625)/2)=
=0.1481
=14.8%
Percent difference in log2: abs(-4-(-3.7859))/((-4+-3.7859)/2)
=0.0550
=5.5%
Why are these two numbers different when I'm reporting a percentage? Shouldn't this percentage be the same since I'm only changing the base but not the values of the measurements?
Thanks again!
Non-constant functions do not, in general, preserve ratios, e.g., : ## \sqrt {\frac {81}{4}}=4.5 \neq \frac {81}{4}=20.25 ##. I think this has to see with the derivative of these functions not being constant, i.e., only when the function ##f ##, as below, is linear.
Basically, few functions preserve ratios, i.e., few functions satisfy:
## \frac {a}{b}=\frac {f(a)}{f(b)} ####
Oh yes, this makes a lot of sense. Thank you WWGD
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
