Escape Speed for Solar System Probe
To escape the solar system from a space station orbiting the sun at Earth's distance, the probe must reach a minimum speed of approximately 41,000 m/s. The initial calculation mistakenly used the radius of the sun instead of the distance from the Earth to the sun. Correcting this, the escape velocity formula is applied with the appropriate values for gravitational constant and mass of the sun. The final consensus among participants indicates that the escape speed should be around 42,100 m/s. Accurate calculations are crucial for determining the correct escape velocity.
Honore
QUESTION:
A space station orbits the sun at the same distance as the Earth but on the opposite side of the sun. A small probe is fired away from the station. What minimum speed (m/s) does the probe need to escape the solar system?
MY UNDERSTANDING AND SOLUTION:
The escape speed v from a sphere of radius R and mass M is given by the energy-conservation equation as follows: (from "Schaum's 3000 Solved Problems in Physics" book, page 101)
(1/2)*m*v^2 = G*M*m / R where;
M: mass of the sun (=1.98*10^30 kg)
m: mass of the small probe
R: Radius of the sun (=6.95*10^8 m)
G: Universal Gravitation Constant [=6.67*10^(-11) Nm^2/kg^2]
From the equation typed in bold above;
v = sqrt(2*G*M / R) and using the numerical values v is found about
616479 m/s .
What do you think?
Thanks.
Six hundred kilometers per second?
Does that sound reasonable?
Always use your head to check your answers.
Without examining too closely, one thing I note is that you haven't calc'd the escape velocity from Earth orbit, you've calc'ed the escape velocity from the surface of the Sun: R = 695,000km. R should be Earth's orbit.
That's why I had to ask.
Okay, let us take R as the distance between the sun and Earth since the problem says "A space station orbits the sun at the same distance as the Earth but on the opposite side of the sun", then v is found
51,393.77 m/s. What about this one?
Is this reasonable? Our professor says yes, but it is incorrect. So what?
Are you sure your numbers were right? You're in the ballpark, but definitely wrong.
The heliocentric gravitational constant (GM) is 1.32712442076 x 10^11 km
One astronomical unit (average radius of the Earth's orbit) is 1.49597871 x 10^8 km
Just eyeballing it tells you your escape velocity will be a little less than the square root of 2000, which puts you in 40's of km/sec.
your equation is right,
vescape = [2*G*M/R].5
your constants must be off
be sure to use:
G = 6.67x10-11
M = (mass of the sun) = 1.99x1030 kg
R = (mean disntance from the Earth to the sun) = 1.5x1011 meters
that should give you the right answer
by the way, the answer should be 4.21x104 m/s
That's great but if he's still struggling with this after five years, he's got bigger problems... :wink:
