How to Estimate Tensile Force on a Pre-Tensioned Rope?
  • Context: Undergrad
  • Thread starter Thread starter Glype11
    Force Tensile
The discussion focuses on estimating tensile force on a pre-tensioned rope, emphasizing the relationship between tension and displacement. Participants highlight the importance of applying Hooke's Law and utilizing force vector diagrams to analyze the system. A simple model is proposed where the pretension is significantly larger than the tension increase due to lateral displacement, allowing for trigonometric calculations. Practical applications, such as using ropes to pull vehicles from mud, are also mentioned.
  • Understanding of Hooke's Law
  • Basic knowledge of force vector diagrams
  • Familiarity with trigonometric principles
  • Concept of pre-tension in ropes
  • Study the application of Hooke's Law in practical scenarios
  • Learn about force vector diagrams in mechanical systems
  • Research trigonometric calculations related to tension and displacement
  • Explore case studies on using ropes for mechanical advantage
Engineers, physicists, and outdoor enthusiasts interested in mechanical systems, tension analysis, and practical applications of ropes in various scenarios.
Glype11
I figure that there is a connection with how much a given forces displaces the rope in the perpendicularly direction. Obviously the more tension on the rope then there will be less displacement with a given force. I'm not sure how to progress from that point.
Any other ideas on how to estimate the amount the force for a rope in tension?
I guess you mean "the more pre-tension ...", because the final tension will be greater with more displacement.
You have to assume some elasticity model of the rope like Hooke's Law and draw a force vector diagram.
When you say perpendicular direction, are you thinking of a case like plucking a guitar string?
A simple model would be one where the pretension is large relative to the increase in tension due to a small lateral displacement -- assume that tension is unchanged. Then all you have to deal with is trigonometry.
Simple model indeed. I overlooked it.
A force that is perpendicularly applied to a pre-tensioned rope can develop a huge mechanical advantage regarding the pulling tension of that rope.
Pulling vehicles out of mud pits using a rope attached to a tree is a known technique.
Please, see applicable examples and calculations:
https://courses.lumenlearning.com/s...-6-common-forces/#CNX_UPhysics_05_06_StuckCar
Here you can see how the Hooke’s law applies to ropes:
https://www.phys.ksu.edu/personal/m...ing/Belaying/ProblemSpringConstantOfARope.pdf
:cool:
  • · Replies 16 ·
  • · Replies 39 ·
  • · Replies 32 ·
  • · Replies 18 ·
