Prooving Euler's Formula: Seeking Direction & Advice
  • Thread starter teclo
  • Tags
    Proof
In summary, the conversation is about proving Euler's formula, e^{i \phi} = cos \phi + i sin \phi, using either a Taylor series expansion or a differentiation/integration approach. The conversation also briefly touches on the definition and properties of complex numbers. The individual seeking help is struggling with the series approach and is looking for guidance.
teclo
117
okay, so I'm really confused, and I'm not sure where to even start. any direction or advice, would be most appreciated.
for an exercise, we were asked to proove 'euler's formula' (not the polyhedron one)
[tex]e^{-i \phi} = cos \phi + i sin \phi[/tex]
for the 'hint' we were given
[tex]e^x = \sum_{n=0}^\infty \frac{x^n}{n!}[/tex]
so yah, like i said any direction would be most appreciated.
You could expand it as a taylor series. You could also do the following:
[tex]z=\cos{\theta}+i\sin{\theta}[/tex]
[tex]\frac{dz}{d\theta}=i\cos{\theta}-\sin{\theta}=i\left(\cos{\theta}+i\sin{\theta}\right)=iz[/tex]
[tex]\frac{dz}{z}=i d\theta\implies\ln{z}=i\theta\implies z=e^{i\theta}[/tex]
I think you mean
[tex]e^{i \phi} = cos \phi + i sin \phi[/tex]
Expand both sides in series and show they are equal.
For such a proof to be valid you must
-define exp(z) for complex z (or at least imaginary)
-show that the power series for exp(z) holds when z is complex (or at least imaginary)
-show that the series converges absolutely so that rearangment is allowed
okay yah i have no clue. taylor series i might be able to manage, i don't know. i'll check the calc 2 book tommorow when I'm not drunk and have electrodynamics in six hours. i have no clue about imaginary numbers, it's been almost ten years since i was in high school working with them. where does z come from, and where can i get some clue as to this i business. i can follow the differentiation (almost). there may very well be no negative, i have had calculus 1 & 2 and that's it. working on 3 now, and this book on modern mathematical physics is mildly terrifying.
thanks so much, i really appreciate the effort afforded.
cheers
cheers
Worry not those into math books for science usually only assume one year of calculus. z is just the variable commonly used for complex numbers. Complex numbers are just a field extension of reals. That means your familar field axioms hold and you have an element i such that i^2=-1. The formal manipulation such books like is something like
[tex]e^{i\phi}=\sum_{n=0}^\infty \frac{(i\phi)^n}{n!}=\sum_{n=0}^\infty \left((-1)^n\frac{\phi^{2n}}{(2n)!}+(-1)^n\frac{\phi^{2n+1}}{(2n+1)!}i\right)=\cos(\phi)+i\sin(\phi)[/tex]
Another way to do the same thing is to note that is two analytic functions (those that can be represented by taylor series) have derivatives of all orders (0,1,2,...) equal at a point, then they are equal.
[tex]f(x):=e^{i\phi}[/tex]
[tex]f^{(n)}(x)=i^n e^{i\phi}[/tex]
[tex]f^{(n)}(0)=i^n[/tex]
[tex]g(x):=\cos(\phi)+i\sin(\phi)[/tex]
[tex]g^{(n)}(x)=\cos(\phi+n\pi/2)+i\sin(\phi+n\pi/2)[/tex]
[tex]g^{(n)}(0)=\cos(n\pi/2)+i\sin(n\pi/2)[/tex]
[tex]g^{(n)}(0)=i^n[/tex]
so they are equal
For any of that to have meaning as I mentioned before we need
okay, thanks again for the help. i was quite fond of the differentiating/integrating approach outlined above. i didn't understand it at first, but then i looked at what was going on and derived the steps myself.
as far as the series approach goes, I'm stuck at step two, which is pretty sad. well, it's not exactly step two, but i did all the steps at once. anyway:
(sorry the tex effort would be horrendous and i can't seem to post an image)
http://mypage.iu.edu/~nlcooper/mathe.jpg
anyone adept at the series math want to help me out from here? just a hint on what to do next would be appreciated over the solution. maybe i made a mistake, i really do need to brush up on the chapter on series from calc 2. thanks again for any help already given and any to be afforded.
cheers
edit i did forget the [tex](-1^n)[/tex]
wow i also forgot a [tex](2^n + 1)[/tex] in the denominator
1. What is Euler's formula?
Euler's formula is a mathematical equation that relates the trigonometric functions cosine and sine to the complex exponential function. It states that e^(ix) = cos(x) + i*sin(x), where e is the base of the natural logarithm, i is the imaginary unit, and x is any real number.
2. Why is it important to prove Euler's formula?
Euler's formula is an important tool in mathematics and has many applications in various fields such as physics, engineering, and signal processing. Proving it provides a deeper understanding of the relationships between different mathematical concepts and can lead to further discoveries and advancements.
3. How can one go about proving Euler's formula?
There are several ways to prove Euler's formula, including using complex analysis, Taylor series, or differential equations. Each approach requires a strong understanding of mathematical concepts and techniques, and may involve advanced mathematical concepts.
4. What are some tips for proving Euler's formula?
Some tips for proving Euler's formula include breaking the problem into smaller, more manageable parts, utilizing known identities and properties of trigonometric functions and complex numbers, and seeking guidance from a more experienced mathematician or teacher.
5. What are some common challenges encountered when trying to prove Euler's formula?
One of the most common challenges encountered when proving Euler's formula is understanding and manipulating complex numbers and their properties. Another challenge may be understanding and applying advanced mathematical concepts and techniques, such as complex analysis or Taylor series expansions. It may also be difficult to visualize and intuitively understand the relationship between the different mathematical concepts involved.
  • Precalculus Mathematics Homework Help
