Exactly how do pressure waves work at the molecular level?
49 replies · 7K views · last reply
Freixas
I've searched high and low for an answer to my question and I can't find a thing.
Let's say I blow into the end of a tube. The opposite end is connected to a reed; when the air hits the reed, the reed vibrates and I can hear a sound. The harder I blow, the louder the reed sounds. I've tested this with a 15' tube while standing about 10' feet from the reed (the tube was partially coiled). The reed seems to respond immediately. If the pressure I create by blowing is transmitted down the tube at the speed of sound, then there is a 22ms latency in this system--that is, when I blow, the sound begins about 22ms later. If I blow less, the sound becomes quieter 22ms later.
Musicians can detect latencies of more than 12ms, but it varies by individual. Let's just say that I didn't notice any delays and so my test system suggests that the pressure changes at the starting end of the tube travel at close to (or faster than) the speed of sound.
Most web pages that cover this topic usually start talking about sound, where the air molecules vibrate back and forth a tiny distance and, on average, don't go anywhere. But in the case I'm looking at, if I blow air in at 0.2 m/s, then air needs to flow out the other end at around 0.2 m/s (with perhaps a slight loss due to friction) and this velocity change (not just the wave front) has to travel down the tube at roughly the speed of sound (or faster).
Because it's hard to study the situation when things are changing continuously, let's imagine that we can immediately go from a flow of 0 m/s to 0.1 m/s. At the instant I start, the molecules of air in the tube are moving, on average, at 0 m/s. The are about to encounter an incoming wave of molecules whose average velocity is 0.1 m/s.
I've tried to picture what happens by using a billiard ball model, with billiard balls sitting on a perfectly flat, frictionless surface. I imagine a row of balls spaced out evenly and lined up perfectly (this is a one-dimensional model of a 3 dimensional problem). An incoming ball hits the first ball in the line and transfers all its kinetic energy to that ball. If the incoming ball is moving at 0.1 m/s, then after the collision its velocity is 0 and the ball it hit is now moving at 0.1 m/s and headed to the next ball in line.
The ball that stopped after the collision has many more balls coming toward it at 0.1 m/s, so it will get moving again. But the wave front (the collisions at the head of the line) doesn't appear to be moving any faster than 0.1 m/s. What needs to happen is
  • The wave front should be traveling faster than 0.1 m/s.
  • Every molecule behind the wave front needs to be traveling 0.1 m/s.
The only derivation of the speed of sound that I've seen is at https://courses.lumenlearning.com/suny-osuniversityphysics/chapter/17-2-speed-of-sound/. The derivation involves a lot of formulas; by the time I reach the end, I have absolutely no intuitive feel for what might be happening at the molecular level.
I'd be happy even with an explanation that showed how the wave front could move faster than the molecules flowing in without worrying about exactly how much faster this is. This still needs to explain how every molecule behind the wave front is moving at 0.1 m/s. In other words, the wave front, while moving (much) faster then 0.1 m/s, has to somehow speed up all the molecules it encounters to 0.1 m/s (on average).
This is a visualisation of sound waves, where the molecules on average travel at 0 speed:
For your case the cylinder should stay at the right most position. But I cannot find a visualisation of that.
Arjan82 said:
For your case the cylinder should stay at the right most position. But I cannot find a visualization of that.
That's been my problem, too. The visualization above is also a simplified to where it's a bit confusing. We can sort of intuit why the particles move to the right when the compression wave hits, but it's less obvious why they move the left when the rarefication wave hits. I understand why—I'm just saying this model doesn't provide any clues.
Also, it's probably not correct to say that, for my case, the piston should stay to the right. In my case, the piston should keep moving to the right, although maybe that's not correct either. In my case, the piston is a long ways outside the tube. In moves continuously in the direction of the tube without reaching the tube and we begin at time 0, when the first molecules moving at 0.1 m/s reach the tube entrance.
I'm not quite sure of the confusion...
If you take a solid steel bar, and push one end at ##0.1m/s## are you surprised when the other end moves (seemingly) immediately ?
Yes I find it more surprising for gas.
For the OP Feynman's lecture on sound is worth looking at (just hit the highlights)
In particular he shows the speed of sound $$c_s=\sqrt \frac \gamma 3 v_{ave}$$
Where ##v_{ave}## is the average thermal gas molecule speed and ##\gamma## is ~1.4 for air
If you take a solid steel bar, and push one end at 0.1m/s are you surprised when the other end moves (seemingly) immediately ?
No force is transmitted "immediately". A force applied to one end of a steel bar is limited at least by the speed of light, although I believe it travels much more slowly.
Everything I'm interested in is in the parenthesized disclaimer "seemingly". In any case, the explanation for a steel bar is totally different from the explanation for a gas. But even for a steel bar, the question should not be whether I was surprised; it should be why you wouldn't be curious. How exactly does the force applied to one end of a steel bar get converted to kinetic motion for particles at the other end of the steel bar?
Forces travel differently in solids than in gases because the molecules are connected in one and not the other. I'm not saying I understand the process any better in solids than in gases; I'd be happy to learn the answer for just gases right now.
Here's a picture of what happens based on observations:
Diagram of a tube 1 m long showing air flow over nine time steps from 0 to 8 ms, with flow speeds of 0.1 to 0.3 m/s as colored arrows and shaded wave fronts.
We have a stream of air flowing in. Let's assume we can increase the air flow in steps of 0.1 m/s. The diagram shows what happens as the air flow increases to 0.3 m/s and then drops back to 0.
After 1 ms, everything in the green box is moving at 0.1 m/s. The thin black vertical line near the opening is suggestive of how far the air the flowed into the tube has moved—it's not to scale. The pressure wave is traveling at the speed of sound, however, and has covered about 1/3 of a meter. The air behind the pressure wave is all traveling at 0.1 m/s.
In 3 ms (roughly), air flows out of the tube at 0.1 m/s. It continues to do this for 1 ms, after which it jumps to 0.2 m/s, etc.
If I try to picture this at the molecular level, I picture billiard balls. As I described in my OP, I can't see any way to make the pressure wave travel faster than the speed of the air coming in. Even if I could, I have to explain why the molecules behind the pressure wave are accelerated to 0.1 m/s, then 0.2 m/s, etc. Explanations for sound waves usually have the pressure wave moving at the speed of sound, but the particles just "vibrate" in place.
Since everything really happens as general trends in the somewhat random interaction of trillions of molecules, it seems it should be possible to explain what's going on at that level. I thought this would be a simple question, but I've asked it elsewhere as well to a deafening silence.
Thanks. I'll take a look—maybe it will clarify things. As I said, I've seen a mathematical derivation (I included a link in the OP)—it makes nothing intuitive.
It's interesting the derivation I saw derives a different formula.
You are assuming the velocity of an undisturbed air molecule is zero. It isn't. It's between 300 and 500m/s. Air molecules don't just float there like in the animation. They are are moving all the time, constantly bouncing off one another, at 3-500m/s due to their kinetic energy. That is what gives a gas its volume. Otherwise, it would collapse to almost zero volume.
When a molecule gets bumped by the inrushing air, its velocity is only changed to somewhere from 299.9m/s to 300.1m/s.
In other words, it could be said that the individual molecules in the ebb/trough of the waves still have a velocity of a whopping 299.9m/s in the direction against the stream of air. They can easily backfill the rarefied volume.
Start at the end (sec 45-5) and expand from there. Hope it helps.
Actually, no, I was assuming the average velocity of air molecules in the tube at the start was 0.
Agreed. And, on average, the velocity of a billion or so of these molecules is now 0.1 m/s in the direction of the tube's axis.
Yes, agreed, I have no problem with the concept of how many random molecule collisions cause molecules to travel from areas of compression to areas of rarefication.
I still have the same two questions:
  • From a molecular point of view, why does the pressure wave travel much faster than the average speed of the molecules that caused it? I don't need the formula or the derivation of the formula or an exact number—just a sense for how it happens. Everything that happens in a gas is due to transfer of kinetic energy through collisions—or, at least, that's how I think it works.
  • Again, from a molecular point of view, why the do molecules trailing the pressure wave get accelerated up to (in the first step) 0.1 m/s? Keep in mind the pressure wave's speed is the same in all cases, no matter what the speed is of the air left behind. (And, yes, in some of my steps the air following the pressure wave is decelerated.)
The one-dimensional billiard ball model was my attempt at condensing billions of molecules into averages. Each billiard ball represents the average velocity of billions of molecules. The spacing between the billiard balls also represents the average spacing of those molecules. My theory is that what happens to the billiard balls and the average of what happens to the molecules is the same. Clearly, this can't be right since I can't create a pressure wave that travels faster than the incoming molecules.
It does not! Read Feynman. Thats the point...
The collisions all take place at the speed of sound. The wave travels at that speed. But the drift velocity of the net motion mimics the drift velocity of the incident wind. (0.1 m/s)
Because that molecule is actually moving at >= 300m/s. If it gets a bump of .1ms, now it can travel at 300.1m/s to reach the next molecule - way faster than .1m/s. It's only adding .1m/s to the already existing 300m/s. And that is the speed at which one molecule can transmit its kinetic energy to the next.
They don't. They get accelerated from 300m/s to 300.1m/s.Think about a bar of steel. If a wave could only be transmitted as fast as the input, then moving one end up at .1m/s would mean that wave could only propagate the length of the bar at .1m/s.
In fact, we know that atoms in a bar of steel can transmit their energy at the speed of sound in steel.
You move the bar, and that signal is propagated at 6000m/s.
In air, it's similar. The air can transmit a signal at >= 300m/s (i.e. the speed of sound in air).
I just got a bunch of comments. Before I say anything else, let me say I appreciate everyone's time in helping me work through this.
This is in response to my comment "From a molecular point of view, why does the pressure wave travel much faster than the average speed of the molecules that caused it?"
Hmm... I thought I phrased this carefully. The average speed of the molecules is 0.1 m/s (as an example). The speed of the pressure wave is something like 343 m/s. So perhaps I'm being dense, but it looks like my original comment is correct.
I did wade through part of Feynman's post. He seems to drop the molecular view pretty early on: "It is clear that we are going to describe the gas behavior on a scale large compared with the mean free path, and so the properties of the gas will not be described in terms of the individual molecules."
So perhaps there is no way to ever conceptualize the behavior at the level I want. I'll keep wading, though.
hutchphd said:
The collisions all take place at the speed of sound. The wave travels at that speed. But the drift velocity of the net motion mimics the drift velocity of the initial wind. (0.1 m/s)
The Feynman post doesn't include the term "drift" anywhere, but I can look it up. My guess is that you mean the average velocity.
The collisions all take place at the speed of sound? I'm just not sure what you mean. I thought the molecules were all zipping about with different velocities, so collisions could occur at all sorts of speeds, but maybe you meant something else.
DaveC426913 said:
Because that molecule is actually moving at >= 300m/s. If it gets a bump of .1ms, now it can travel at 300.1m/s to reach the next molecule - way faster than .1m/s. you're only adding .1m/s to the already existing 300m/s. And that 300/ms is the speed at which one molecule can transmit its kinetic energy to the next.
I cannot picture a particle moving at 0.1 m/s catching up to a particle traveling at 300.1 m/s to transfer all its kinetic energy to the latter and create a particle traveling at 300.1 m/s.
But let me try your system. I'm going to have to simplify to have any hope of an intuitive understanding:
  • Let's keep all motion 1-dimensional.
  • Let's begin with all particles evenly spaced.
  • Each particle in the tube is moving at either -300 or +300 m/s.
  • The particles in the tube alternate velocity, so if one is going at -300, then next is going at +300.
  • The incoming particles are set up the same way, but with velocities from -299.9 to +300.1 m/s.
Let's say the first incoming particle is moving at +300.1 and the first particle in the tube is moving at -300. We place these two particles at the tube entrance to begin.
This leaves us with one particle traveling at +0.1 at the entrance. All other particles in the tube then collide with a net velocity of 0. All other incoming particles collide with an net velocity of +0.1. I'm back to my original billiard ball model. I don't see how randomizing the velocities will help or even randomizing the velocity's direction as long as the averages remain at 0 for the tube and 0.1 for the incoming air.
Oh, well... I'll go ponder Feynman some more and maybe lightning will strike.
How did you get that one particle at +0.1? These are elastic collisions, so after the collision the incoming particle is traveling at -300 and the first particle in the tube is traveling at +300.1.
A.T. said:
How did you get one particle traveling at +0.1 ? Assuming elastic collision and same mass, the -300 will change to +300.1
Ignorance? Walk me through this: +300.1 meets -300. Are you saying that after collisions the +300.1 becomes -300 and the -300 becomes +300.1?
If so, I can try to step through my simplified version again.
Consider if the particle hits a brick wall and the collision is elastic. What velocity does +300.1 rebound at?
No, let's not use a brick wall. Let's get two elastic cars (equal mass). First, the head straight towards each other at 300 m/s. My assumption was that the net result would be tow cars at 0 m/s, but I realize now that that doesn't conserve kinetic energy (I peeked at Wikipedia while you were typing). They swap directions and maintain speed.
The next case is that one of the cars is moving at 300.1 m/s and the other at 300 m/s. According to Wikipedia, the velocities and direction swap.
As I said, let me work through the one-dimensional example again.
Elastic cars are tough because cars are designed to be inelastic, but ok...
Freixas said:
average speed
There is a difference between average speed (300 m/s, give or take - directionless) and average velocity (0.1 m/s, give or take - vector-valued).
In your model the gas you introduce will also be at temperature so your model is no good. The gas you supply (blow in) is at room Temperature so it is also zooming at +/-300m/s plus 0.1m/s.
Let's do this instead:
Suppose you increase the "rebound" speed of the left end molecule of the 1D gas (by 0.1m for one rebound). That speed anomaly will be transferred at each subsequent particle collision along the chain until it reaches the right end. The speed of the transfer will be 300m/s and the excess speed of the "other" end particle will be 0.1 m/s . I think this works to explain the physics?
Hand-annotated space-time diagram with Distance on the horizontal axis and Time on the vertical axis, showing zigzag red and orange wave paths bouncing down a tube, a blue line labelled .1m/s, and green text reading That .1m/s additional velocity is propagated down the tube at 300m/s.
Thanks everyone!
Using the helpful prod on elastic collisions and the notion of speed (directionless) vs. velocity (vector), all this seems to fall into place. The speed of sound in dry air at 20° (presumably at 1 atmosphere) is 343 m/s. So all the air in my example has an average speed of 343 m/s with the air in the tube having an average velocity of 0 and the air coming in having an average velocity of 0.1 m/s into the tube, then the solution seems intuitive (easy to imagine without needing pencil and paper or other device).
But Wikipedia says: "The speed of sound in an ideal gas depends only on its temperature and composition. The speed has a weak dependence on frequency and pressure in ordinary air, deviating slightly from ideal behavior." Let's ignore frequency and pressure for the moment.
I set up my one-dimensional model. Using my new concepts, I see the wave front advancing at a velocity of, not 343 m/s, but 343.1 m/s. Oops!
My one-dimensional model test case had the particles in the tube traveling at either +343 m/s or -343 m/s. The ones streaming in had velocities of either -342.9 m/s or 343.1 m/s. So the wave front basically swaps a -343 m/s particle with a +343.1 m/s particle.
I had better draw this. In the tube at the wave front, we see this
+343.1 → ← -343 becomes -343 ← → +343.1​
The particles streaming in look like:
+343.1 → ← -342.9 +343.1 → ← -342.9 +343.1 → ← -342.9 +343.1 → ← -342.9​
so all the rightward moving particles are at 343.1. At the wavefront, we can expand the picture to look like this:
+343.1 → ← -343 +343.1 → ← -343 +343.1 → ← -343 +343.1 → ← -343 +343.1 →​
Hmm... The average speed is 0.1 m/s. The average velocity is 343.05 m/s, but the wavefront is at 343.1 m/s. You can't have the wavefront influenced by the average speed or else you get all sorts of artifacts.
(DaveC426913, your drawing arrived while I was typing all this. It helped me find the problem in the above diagram)
Ok, the error is that I have particles colliding in synch even though they are moving at different speeds. Using DaveC426913's diagram, it is much clearer that the wavefront advances at +343 m/s (or whatever the average speed is) and the particles left behind move at an average speed of 0.1.
The other thing is Wikipedia's claim that this depends on temperature and composition. I seem to have only taken temperature into account. I'm assuming composition includes fluid density. If we pack the particles closer or further in my little model, it makes no difference (a change in temperature, however, seems to have a direct influence).
This is quite a step up from where I was when I started!
The speed of sound is the speed at which bulk density variations propagate. It is related to the speed of the air molecules but it is not identical to that speed.
I think what they mean by composition is really the type of molecules. If I remember correctly from classes a long long time ago molecules also have internal vibration modes, i.e. vibration of the different atoms within a molecule, and molecules can also rotate and thus may have different angular momentum (These are considered internal degrees of freedom). In this case the elastic collisions can also convert energy into these vibrations or into rotation which means the velocity after collision is different, this matters.
Density itself is not directly influencing the speed of sound. Read also this part on wiki:
https://en.wikipedia.org/wiki/Speed_of_sound#Details
In the end the speed of sound, ##c##, for an ideal gass is:
c = \sqrt{\frac{\gamma \cdot k \cdot T}{m}}
It is a function of:
  • ##T##: Temperature: some measure of the average kinetic energy of the particles
  • ##k##: The Boltzmann constant, relating the temperature to the average kinetic energy
  • ##m##: The mass of a molecule, equal momentum for a particle with higher mass means lower velocity
  • ##\gamma##: And the adiabatic index, this is actually taking into account the internal degrees of freedom of a gas. According to the lecturenotes on gasdynamics I still have: "for air considered to be a di-atomic gas with 5 degrees of freedom (i.e. ##n= 5####) \gamma = \frac{n+2}{n} = 7/5 = 1.4##)" which is indeed the adiabatic index for air.
By the way, this formula for ##\gamma = \frac {n+2}{n}## apparently follows from the kinetic theory of gasses. Which is actually trying to model the properties of a gas by colliding particles.
Thanks for the clarification. I had seen the notes you mentioned, but I didn't know how to translate them into my billiard ball model. I think I see now. Terms ##T##, ##k##, and ##m## are what you need to calculate the average speed of the molecules using things we can measure at the macro scale.
##\gamma##, the adiabatic index, is harder to understand. I looked into it a bit. It sounds like it is another factor needed to compute average speed of the particles because the collisions may not be purely elastic; some energy could be transferred to rotational motion (I'm imagining it like putting spin on a billiard ball), for example, and not contribute to the average speed.
So, if we somehow (magically) know the average speed of the particles, we don't need to look at anything else—we know the speed of sound in that medium. Wikipedia's statement about temperature and composition just means that, lacking magic, we need to know those things in order to determine the average speed.
Thanks, everyone! I didn't think I'd get an answer I could follow.
Which is of course the same result derived in Feynman (https://www.physicsforums.com/posts/6398388/bookmark) .
In equilibrium (meaning Temperature is defined) each degree of freedom (possible motion of a system) is apportioned on average ##\frac {kT} 2## of energy. It is the definition of Temperature. So physics supplies the magic...
It's often forgotten to mention a very important assumption when quoting the equipartition theorem. The complete statement is: Each phase-space degree of freedom that appears quadratically in the Hamiltonian provides and average energy ##k_{\text{B}} T/2## when in thermal equilibrium with a heat bath at (absolute) temperature ##T##.
DaveC426913 said:
Sorry, I'm back. I was thinking of how to explain this to someone else (always a good test) and things aren't working out.
The diagram above mixes average relative velocities (.1 m/s) with absolute speeds (300 m/s). So the blue line, if we were to remain consistent, would be a particle traveling at 300.1 m/s. We can still follow the diagram from this point, though.
The diagram states that the .1m/s is propagated at 300 m/s. Given what I learned about elastic collisions, the particle hit by the incoming 300.1 m/s particle will now move right at 300.1 m/s. Every 300 m/s particle it hits from then on will move at 300.1 m/s. So the wave front is propagated down the tube at 300.1 m/s.
To infer this, I don't need to calculate exactly when each collision occurs. I just need to track the leading particle, which is always going to move at 300.1 m/s. It's not the same particle all along the way, but that doesn't matter.
This doesn't sound right. Now 0.1 m/s is not much speed, but it could be 50 m/s and now we're getting wavefronts traveling at significantly different speeds.
Am I wrong? Did I miss something?
It's an average.
You do not have a leading particle always advancing at exactly 300.1 m/s all the time. You have a collection of particles moving in random directions at significantly more than 300 m/s. It is the peak of the density distribution that advances at 300.1 m/s.
In my [very strongly held] opinion, trying to understand this at the molecular level is the wrong thing to do. You know that it will work out because ideal gas behavior follows from molecular behavior and pressure waves follow from ideal gas behavior. Trying to jump directly from one abstraction layer to another two hops away is not optimal.
