Solving Exchange of Momentum by Conserving Energy & Momentum
The discussion revolves around a physics problem involving a block of wood shot upwards from two different points. It explores how the center of mass (COM) of the block rises in two scenarios: when the bullet is fired at the center versus near the support end. The key point is that while both scenarios result in the same height for the COM, the second case involves rotation, affecting energy distribution. The conservation of momentum ensures that the heights remain equal, despite the energy being partially converted to rotational kinetic energy. Ultimately, the analysis concludes that the height achieved by the COM is the same in both cases, highlighting the complexities of energy conservation in rotational dynamics.
pukb
Imagine a block of wood resting on two supports at each end. You point a gun upward under the block and shoot the block upwards.
One scenario is you shoot the block upwards in the exact center. Another scenario is you shoot upwards near one of the support ends. The block is thick enough that in both cases the bullet comes to rest inside the block.
Question: in which case does the centre of mass of the block rise the highest?
I could quantify the first case (both for velocity and distance rise of cog) using conservation of momentum and conservation of energy as follows:
mu = (m+M)V
1/2(mu^2) = (m+M)gh
Can somebody help me in the second case?
hi pukb! :smile:
hint: in the second case, why does 1/2 mu2 = (m+M)gh not work? :wink:
yes, it does apply - what i meant was the heights to which cog is lifted are not same when force is applied at center and at corner because the latter case will cause some rotation as well. The problem is to quantify that
hi pukb! :smile:
(btw, it's better to say centre of mass, com, than centre of gravity, cog :wink:)
pukb said:
…the latter case will cause some rotation as well.
yes! … so the kinetic energy will be the "translational" kinetic energy 1/2 mv2 plus the rotational kinetic energy 1/2 Iω2 :wink:
There's a video of this very problem on YouTube. The results are not exactly what you'd expect. The video does compare two wooden blocks, one shot thru the CG and the other shot off-center. Both went the same height into the air. Of course, this raises the question of what happened to the conservation of energy. The block that's spinning should not go as high into the air due to energy being transferred as angular momentum. But it does. What gives?
The video proposed an answer that both blocks must go the same height in order to conserve linear momentum. The difference in energy is due to the bullet not traveling as far into the wood (doing work in the process) and that difference in work is getting translated into angular energy.
Yes, it's not a comforting explanation. But it does seem to be correct.
Likes 1 person
Hi Ryoko! :smile:
Yes, I didn't think this through fully :redface:: the energy equation which I said didn't work …
should be 1/2 mu2 + 1/2 Iω2 = (m+M)gh + 1/2 Iω2,
which of course is the same equation, with the same u (since u is fixed by conservation of momentum, irrespective of ω and of the slight difference in I).
So h (the height) will be the same in both cases.
Thanks, Ryoko. :smile:
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
