f-h said:
Obviously they disagree. :) I'll page Francesca to see if she wants to respond to this.
Obviously I disagree
we have been chatting about this a while...
f-h said:
It is certainly necessary to restrict the class of 2-complexes. Otherwise even at the 1-vertex level you can construct arbitrarily many divergent 2-complexes. The most plausible such restriction I've seen this far is this:
http://arxiv.org/abs/1107.5185
It is likely that there could be a restriction, even if I would not say that it's "certainly necessary". I agree that this is something that has to be studied, thank you to point to the new paper by the Polishes, it seems very interesting!
f-h said:
As for my paper, the central question I ask is what is the physical meaning of the expansions done. That is, given how we want to interpret the theory, what physical regime do these calculations reflect.
This has been the focus of my work of the last few years. A brief summary can be found in http://arxiv.org/abs/1107.2633" .
f-h said:
My proposal is that the approximation calculated by them is on a spacetime of form B^4 u B^4, that is, the 1 vertex level approximation leads to disjoint spacetimes, they argue that it leads to cosmological spacetimes (too), so who is right?
We are both right! There is a factorization and there is a cosmological interpretatation, why not?! This is in the same spirit of what has been done in covariant quantum cosmology so far, I think in particular to the
no-boundary proposal of Hawking, but also to Vilenkin's wave function and so on...
The factorization of the transition amplitude, that leads to the 2 disjoint spacetimes, is nothing surprising: it is inherited from the classical theory and the usual expression of the transition amplitude. In fact in http://arxiv.org/abs/1107.2633" you can read
The classical Hamilton function of a homogeneous isotropic cosmology is the difference between two boundary terms. With the cosmological constant [itex]\Lambda[/itex] it gives
[itex]
S_H= <br />
\int {\mathrm{d}}t\, (a\dot a^2 + \frac\Lambda3 a^3)\Big|_{\dot a =\pm \sqrt{\frac\Lambda3} a}= <br />
\frac23 \sqrt{\frac\Lambda3} (a^3_{fin}-a^3_{in})[/itex]
where [itex]a[/itex] is the scale factor and [itex]\dot a[/itex] its time derivative. Therefore at the first order in [itex]\hbar[/itex] the quantum transition amplitude factorizes:
[itex]W(a_{fin},a_{in})=e^{\frac i \hbar \,S_H(a_{fin},a_{in})}=W(a_{fin})\overline{W(a_{in})}[/itex] .
The same happens for the spinfoam amplitude
[itex]
\langle W |\psi_{H_\ell(z_{fin},z_{in})}\rangle=W(z_{fin},z_{in}) = W(z_{fin})\, \overline {W(z_{in})}[/itex] .
In simple words, this is saying that at the first order the probability to go from a state 1 to a state 2 is given by the probability of 1 to exist times the probability of 2 to exist. And, this is remarkable, the distribution of probability for a state to exist is peaked when the state, labelled by the scale factor [itex]a[/itex] and the extrinsic curvature (related to [itex]\dot a[/itex]), satisfies the right relation between [itex]a[/itex] and [itex]\dot a[/itex], namely the Friedmann equation [itex]\left(\dot{a}/a\right)^2=\Lambda/3[/itex] (in absence of matter, matter can be easily added in this spinfoam framework in effective way, in the same manner we have added the cosmological constant in http://arxiv.org/abs/1101.4049" ).
Said so, I'm of couse interested in studying the next orders. Spinfoam Cosmology moves together with the new results in the full theory: a year ago only the fist order were available, now we have Mingjy's computation of the 3-point function. Therefore now we have more technologies to study the correlation between 2 cosmological states, even if the actual computation is cumbersome and it has not been done yet. Nonetheless, we have so much to learn from the first order!
f-h said:
My observation in the paper is that the 2-point correlation function between any observables on the two components of the boundary vanishes at the 1-vertex level exactly (that is, at any level of the graph truncation, for any boundary state, and without going to the asymptotics). Thus if you want to keep the interpretation of the 2-point functions that underlies the graviton propagator, this has to correspond to a space time topology which completely prevents any propagation, that is, one that is disjoint.
Again, this seems just to indicate that the correlations will appear at the next order, I totally agree and I have pointed to this me too. See http://arxiv.org/abs/1107.2633" .
The main open issue remains the computation of quantum corrections. Higher order quantum correction can come by considering more than one vertex in the spinfoam. We are not interested in a mere sequence of edges and vertex, because it has to be equivalent to a single vertex [http://arXiv.org/abs/1010.4787" ]. We would like to have instead spinfoam faces spanning from the initial to the final states and carrying the correlations between the two states (see FIG.4).
