Exit flow rate in a Plate Heat Exchanger
The discussion revolves around calculating the flow characteristics in a cascade system of plate heat exchangers used for heating water. The initial setup involves hot water from a boiler entering the first heat exchanger at 65°C and exiting at 50°C, while the second heat exchanger heats water from 10°C to 45°C. The main inquiry is whether pressure loss in the heat exchanger affects the velocity and flow rate of the water at the outlet. It was clarified that while pressure loss exists, it does not significantly change the velocity or mass flow rate of the fluid. The participant now understands that the mass flow rate remains constant despite pressure variations.
harishree90
TL;DR Summary
Calculation of Exit Mass flow rate in a Plate Heat Exchanger to design a Cascade Heating Network
Hello All,
I am working on a project with plate heat exchangers connected in a cascade system to heat up water connections in a huge system
The Problem Statement :
A boiler produces and circulates hot water at 65 degC to a Heat Exchanger and come out at 50 degC, where as the other fluid is also water which needs to be heated to 60 degC from 45 degC , The volume flow rate of hot water is at 5.0 m3/hr and the dia meter of the pipe is DN50
Using energy Equilibrium , Heat transfer rate in the first heat exchanger
Q = m X Cp X ΔT which come around 85KW
now from the outlet of the Heat Exchange in the hot Side which is at 50 degC, I am connecting it as an Input to another heat Exchanger, which is also used to heat water from 10 degC to 45 degC and the hot water connected back to the Boiler which is at 15 degC
My question is, how can I calcuate the volume flow rate or mass flow rate or velocity of water at the outlet in the first heat exchanger which acts as an Input to second HX, so that I can calculate the heat transfer rate of the second HX to determine if need to have a pump in the circuit.
Thanks in Advance
If my question is not clear please let me know
Hello harishree, :welcome:
Your question is indeed unclear to me: if the volume flow is not 5 m3/h, where would the difference go ?
And the 5 m3/h, where does that come from, if not from a pump ?
Or:
With 'outlet' you mean the 60 C outlet ? Your heat exchange rate of 87 kW more or less dictates 5 m3/h too (with the given ##\Delta##T)
Likes harishree90
Or:
Thank you for the reply
The 5 m3/h volume flow at the inlet of the heat exchanger comes from a hot water boiler.
And by Outlet I mean the output with 50 C which acts as a input to the second heat exchanger.
My question is ...due to pressure loss in the heat exchanger (Considering 0,1 bar), will there be a change in velocity of the fluid at the exit (at 50 C) ?
No significant change. And, of course, the mass flow rate won't change at all.
Likes harishree90
Thank you for the explanation Chestermiller and BvU
I was under the wrong idea that since there will be a pressure loss in the heat exchanger, it would affect the velocity and the flow rate also.
Now I understand
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
