Understanding the Exit Pressure of Nozzles in Thermodynamics
Fluid exiting a nozzle experiences a drop in pressure due to the acceleration of flow, which requires a lower exit pressure than the inlet pressure. The misconception that reducing cross-sectional area increases pressure is clarified by understanding that in a nozzle, the pressure gradient drives the fluid toward the exit. While mechanical systems may show increased pressure with reduced area, this does not apply to fluid dynamics in nozzles. The pressure remains constant throughout a nozzle if the fluid is static, but as it accelerates, the pressure decreases. Understanding these principles is crucial for grasping thermodynamic behavior in nozzle applications.
scottymo
Hi There,
Im studying thermodynamics at the moment and there's one statement about nozzles that I just haven't been able to understand. In my mind when a fluid exits a nozzle it would have a higher pressure than the inlet. Could someone please explain in what sense the pressure of a fluid drops as it goes through a nozzle? Are they talking total pressure over an area? my book doesn't explain why just makes that statement.
Thanks in advance
Why would the fluid have a higher pressure at the exit than the inlet? The whole point of a nozzle is that it accelerates the flow. In order for the flow to accelerate, the pressure gradient through the nozzle must be such that the fluid feels a force towards the exit, requiring a lower exit pressure than inlet pressure.
Likes scottymo
I don't know why, I'm clearly wrong on that thought so I'm looking for insight to set my thought process straight on the matter. Maybe its just been beaten into my head to long that you increase pressure when you reduce area. What you say about about the flow seeking lower pressure does however make a lot of sense.
Out of curiosity, in what context did you hear that you increase pressure when you reduce area? It's certainly not generally true. I'm sorry I'm not giving more detailed answers here, but I really don't understand exactly where your confusion is arising from, so it's hard to address it. I'd love to go into more detail though if you tell me what specifically I should expand on...
Well say you take a mechanical advantage piston setup or or the footprint of a column, reducing the area on one of the pistons or at the end of the column will cause a rise in pressure at that point. Thats what I'm used to at least. Now in my mind when I picture a nozzle I see a volume of fluid going in at a certain rate, now the cross sectional area reduces as it travels through meaning less volume for that fluid to occupy, it just makes sense in my head because of this that the pressure of the fluid increases as it travels through the nozzle. I am having trouble getting rid of that notion.
Ahh. This would be correct if you have a smaller piston with the same force applied. However, think instead if that reduction happened in the fluid itself (so you had a large piston, then the fluid reduced down to a smaller diameter below it). Now the pressure in the small diameter region is the same as the large diameter reason (I'm ignoring gravity here). This is more analogous to the nozzle case, where the reduction happens in the fluid itself. If you have a nozzle with static fluid throughout, the pressure will be the same throughout, just as in this piston case. Make sense so far?
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 36 ·
  • · Replies 20 ·
10K
  • · Replies 58 ·
