Exit Temp / Heat Loss in External Pipework
The discussion focuses on calculating heat loss and exit temperature for 100ml of water in a 19mm diameter, 3m long external pipe at -10°C air temperature. The water, initially at 20°C, flows at approximately 0.5m/s and is released via a siphon over 7 seconds. Key parameters include water density (998 kg/m³), thermal conductivity (0.598 W/m·°C), and specific heat capacity (Cp = 4182 J/kg·°C). The user successfully solved the problem and indicated that the thread can be deleted.
  • Understanding of heat transfer principles, specifically conduction and convection.
  • Familiarity with fluid dynamics, including flow rates and viscosity.
  • Knowledge of thermodynamic properties of water at varying temperatures.
  • Ability to apply mathematical formulas for heat transfer calculations.
  • Research the impact of external temperature on heat loss in pipes.
  • Learn about advanced heat transfer calculations using computational fluid dynamics (CFD) software.
  • Explore methods for insulating external pipes to minimize heat loss.
  • Investigate the effects of varying flow rates on thermal performance in piping systems.
Engineers, thermodynamics students, and professionals involved in HVAC design or fluid transport systems will benefit from this discussion.
sam...wise
I have been trying to establish what the heat loss and exit temp (in deg C) for 100ml of water traveling down a pipe located externally to a building and subjected to -10degC air temperatures will be if:
The pipe has an internal diameter of 19mm and a length of 3m.
100ml of water with initial temp of 20degC is traveling in the pipe at approximately 0.5m/s. (The pipe is not full of water).
The 100ml water is being released from a siphon, which takes approximately 7seconds. Flow rate = approx. 14.3ml/s.
Assuming material is temp of external air and thickness is negligible.
Both conduction and convection heat losses will be occurring, but I am not sure which is the greater.
Using, the below for water at 20degC:
density = 998kg/m^3
thermal conductivity = 0.598 W/m.degC
Dynamic viscosity = 1.002 kg/m.s
Kinematic viscosity = 1.004 x10-6
Cp = 4182 J/kg.degC
Pr = 7.01
For convection calcs I have been trying to use Texit = (Tsurface - Tin)e^-(h.A/mdot.Cp) but I could do with clarification of my results, as I am not sure they are correct.
Thank you for any assistance. Please let me know if additional information is required.
I have solved this problem. This thread can be deleted.
