Expected Values in a Harmonic Oscillator
1 reply · 3K views · last reply
Domnu
Problem
Show that in the [tex]n[/tex]th state of the harmonic oscillator
[tex]\langle x^2 \rangle = (\Delta x)^2[/tex]
[tex]\langle p^2 \rangle = (\Delta p)^2[/tex]​
Solution
This seems too simple... I'm not sure if it's correct...
It is obvious that [tex]\langle x \rangle = 0[/tex]... this is true because the parity of the square of the eigenfunction is [tex]1[/tex] (in other words, the probabiliity density is an even function). Now, we know that [tex](\Delta x)^2 = \langle x^2 \rangle - \langle x \rangle ^2[/tex], but [tex]\langle x \rangle = 0[/tex], so by substitution, the desired result follows. A similar argument can be made for the momentum. [tex]\blacksquare[/tex]
You can always explicitly show that <x> = 0 in the nth state if you feel you need to show more work.
To get started try representing x in terms of the raising and lowering operators in the following line, letting the operators act on any kets to their right, and simplifying:
<n|x|n> = ... |n> is the eigenket for the nth eigenstate.You should end up with delta functions that have to be zero.
