Experienced with PQ Control and PI Tuning for Inverter Power Control?
The discussion focuses on modeling active/reactive power management in inverters, specifically implementing PQ control with voltage references. Participants share challenges with PI tuning, noting that the grid's behavior significantly influences P and Q outputs. There is an emphasis on determining the zero-degree reference angle in phase with grid voltage and the importance of actual system frequency. Suggestions include using conventional power plant control methods to improve inverter performance and experimenting with control loops based on Id and Iq. The project centers on distributed energy resources (DER), highlighting the need for effective power control strategies.
GregoryGr
Does anyone have experience modeling active/reactive management in an inverter? I'm working on it for a project, more precisely I'm trying to implement that PQ control with references of voltage, as is seen in this image:
Problem is I've tried many PI regulators, and my I_dq doesn't want to follow the references. Does anybody have experience either on PQ control or in PI tuning (I suppose there is software that can find the optimal PI values? )
How have you modeled the grid? The P and Q output is not determined entirely by the inverter, The grid's behavior plays a major role or even the dominant role.
How do you determine the zero degree reference angle in phase with Ed?
Where does actual system frequency come into play?
GregoryGr said:
I_dq
What is that?
Where does actual system frequency come into play?What is that?
Hm, I haven't really modeled the grid, it's a fixated 3ph sine source with 400 polar voltage/50Hz and an inductance. What did you have in mind for the grid?
The approach was to orient the grid voltage so Vq = 0 as to use Iq and Id for decoupled power control (sensors are placed in the PCC). So in the image i posted in the modulator, the way i try to simulate it, is first to normalize Ed and Eq reference, and then dq->abc with the same angle the field orientation of the grid, which should in theory provide the necessary phase difference and amplitude to achieve PQ control...
(by Idq I meant both Id & Iq)
Thanks for the quick reply :)
See this PF Insights article, especially the equations that describe P and Q flow between two adjacent nodes in a grid.
https://www.physicsforums.com/insights/ac-power-analysis-part-2-network-analysis/
I think your inverter would work better by imitating conventional power plant controls. One loop to control real power by adjusting phase angle. Another loop to control voltage magnitude and therefore Q.
Control loops feeding back Id and Iq rather than V and ##\theta## sound strange to an old-timer like me.
Thank you, I will check this out. What you are suggesting I am currently experimenting with (and even though I haven't managed to work it out, it seems to be responding in the right direction! ). Truth be told, current control without classic hysterysis or bandwidth control seems strange to me too, but it seems to have worked in some papers... The reason I'm attempting that is because in general field control should have a better response.
The topic of my project is about DER sources, so convetional power controls should be on point!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
