Programs Experimental Physics Undergraduate Degree?
For students interested in the experimental side of Physics, degrees such as Engineering Physics, Applied Physics, and Materials Science are recommended, as they often incorporate hands-on experimentation. Condensed Matter Physics is highlighted as a promising field that aligns well with a focus on experiments, particularly those that are less costly and more accessible than large-scale projects. Key areas of knowledge beneficial for lab work include Electronics, Mechanical systems, and Chemistry. As a freshman, it is advisable to explore these subjects both in coursework and through independent study to build a strong foundation for a future in experimental physics.
DrummingAtom
I love the experimenting side of Physics. I know you can't actually major in Experimental Physics so out of a couple degrees which one is most likely to focus on Experimenting. Engineering Physics, Physics, Applied Physics, Engineering, Materials Science?
Also, what part of Physics has a high level of Experimenting involved? Like less expensive experiments, not billion dollar ones. Are there certain areas that are more important than others to know in a lab? Electronics, Mechanical, Chemistry? Ultimately, I just want to know what I should be learning about throughout my college years, in classes and on the side. I'm a freshman, and undecided. Thanks.
After doing a bit of searching I've discovered that the Condensed Matter field seems pretty close to my interests. Does this sound about right?
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
