How Do You Calculate the Equilibrium Constant for This pH Experiment?
  • Thread starter Thread starter Pengwuino
    Ph
The discussion revolves around calculating the equilibrium constant (Keq) for a pH experiment involving the addition of HCl to a weak base. The pH of 5.855 indicates a pOH of approximately 7.161 x 10^-9, leading to confusion about the concentrations of species at equilibrium. Participants highlight the need to clarify whether the base is mono-acidic and to determine which species are in excess after the reaction. It is noted that the initial assumption of half-neutralization is incorrect, as only a small fraction of the base reacts with the acid. The conversation emphasizes the importance of accurately identifying concentrations to properly calculate the equilibrium constant.
Pengwuino
In an experiment we did, we simply added 5ml of 0.1ml HCl into 20ml of a .5M solution of an unknown weak base. I'm not sure how we calculate the equilibrium constant though
We know the pH is 5.855 which means the pOH is 10^-(14-5.855) = 7.161 x 10^-9.
Now I'm a bit confused. Is the [HB+] concentration the same as the [OH-] concentration and is the equilibrium equation this?
Keq = \frac{{[HB][OH]}}{{<b>}}</b>
I think some more information needs to be known. For instance, is it a mono-acidic base (like NaOH)?
What you need to find is which is in excess (ie, at equilibrium, what is the concentration of each species? Is there an excess of the acid, the base or did they react completely?)
The concentration of OH- will be 10^-(14-5.855) = 7.161 x 10^-9 not pOH.
First of all, how did you get that equilibrium equation?
As I said earlier, you need to know what the concentration of the species at equilibrium are before you can find the equilibrium relation
siddharth gave some very good points, however, the premise here is the equation pKa=pH at the half equivalence point as far as this lab is concerned. Both of you should note that, the mixing of the acid and base would result in half of the base titrated.
There is something wrong with the question - there is no base that will give acidic solution when partially neutralized.
Not 50% but 5% of the base was neutralized, so pKa is not equal to pH.
Pengwuino - take a look at this question: calculation of pKa of a weak acid. It describes similar case, so should be helpfull.
Why is that? If it is a mono-acidic base like NaOH, then initially there are 10 mmol of NaOH and 0.5 mmol of HCl. So only 0.5 mmol of the base will react.
Yeah, since there is an excess of the base, I would have thought that the resulting solution will be basic.
I figured the equation should be...
HA_{aq} + B_{aq} \leftrightarrow HB_{aq} + OH_{aq}
HA being the HCl
B being the weak base
HB being the salt
OH being hydroxide
H2O being some strange liquid :P
Then the equlibrium equation should be (after reducing)
Since all the acid was neutralized (or at least i suspect it should have)
yeah, the problem's messed up to begin with, we've got nothing to work with here really so it's somewhat senseless to continue the discussion, so Penguino should restate the problem,
that was stupidity on my part, I assumed that since the experiment involved a simple step to calculate the Ka, that the case here was that of half equilvalence.
Well the problem was very straight forward. We had a solution of HCl and a solution of an "unknown weak base".
I Just realized i should have put "5ml of 0.1M HCl". That was basically what we had to work with and i just assume it. I also skipped a step and said my [OH] was my pOH without clarifying that i was converting to [OH] already.
if it were the simple case where we're dealing with a half-equivalence point problem, then pKa=pH, but from the problem, it doesn't seem that way.
in reference to your original post, the hydroxide term will equal the acid term, before you add the acid. You'll need to make some subsequent rearrangements and then work backwards to solve for Kb. Note that they give you the pH (after adding the acid?), you can use this to solve for the hydroxide term. Let's see what you can do.
Kb=[HA][OH-]/[HA]=[x][x]/[.5M-x] and subsequently
Kb=[.0005M+x][10^{-8.145}]/[.5M-x-.0005M] assuming we're dealing with the buffer region (which may or may not be the case here).
So you've got two equations to work with
Kb=[HA][OH^-]/[HA]=[OH^-] ? :smile:
yeah, thanks for pointing that out
Kb=[HA][OH-]/[A-]
