Explaining Voltage/Current/Resistance to non-physicists
  • Thread starter Thread starter vortmax
Many students struggle to visualize voltage, current, and resistance in an E&M lab, despite having a background in mechanics. A common and effective analogy is comparing electrical concepts to water flow, where voltage represents water pressure, current is the flow rate, and resistance is akin to a restriction in a pipe. To enhance understanding, incorporating the Drude model can provide a more accurate depiction of how potential energy dissipates in a circuit. This approach can help bridge the gap between mechanical concepts and electrical principles. Using relatable analogies and models can significantly aid in teaching these fundamental concepts to non-physicists.
vortmax
I'm a TA for a sophmore level E&M lab course that is taught independent of the lecture. So most of my students are seeing these concepts for the first time in the lab setting (learning through discovery).
Many of them are having problems visualizing the concepts of the voltage, current and resistance. However, most of them have had mechanics, so they understand the concepts of potential energy and work.
I understand the fundamentals of E&M, but I'm having a hard time describing it in ways that the students can grasp and internalize. I've managed to make some promising headway by making the parallel between electrical potential and gravitational potential and relating that back to voltage, but am not sure how (or if it's worthwhile) extending that metaphor further.
So, can anyone have a solid, basic description of voltage, current and resistance that would make sense to someone who has had basic mechanics?
The most useful (and common) analogy is that of water. Batteries and other voltage sources are pumps. Voltage is water pressure. Current is the flow of water. Resistance is a restriction in a pipe, or a sponge shoved into the pipe.
- Warren
I agree with chroot, the water analogy is usually the most accessible. For a more physically correct description, familiarize yourself with the Drude model and you could use that to explain the dissipation of potential energy throughout the circuit and thus explain resistance, current and voltage drop.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
