Explicit variable from equation
  • Thread starter Thread starter terminal
    Explicit Variable
terminal
hi all!
I'm facing this problem and I can't get a solution, I want to explicit variable m from the following equation, I tried with binomial theorem to break up binomial coefficient but it was useless...
can someone help me please?
\sum_{i=n}^{n+m}\binom{n+m} {i}p^i(1-p)^{n+m-i} = k
all variables are known except m, and k is a known constant.
virtually I'd like something in the form:
m = g(n,p,k)
thanks!
Mathematics news on Phys.org
Look at a couple of simple examples. Suppose m= n= 1. Then that says
\sum_{i=1}^{2}\binom{2}{i}p^i(1-p)^{2-i} = k
which is
\binom{2}{1}p(1- p)+ \binom{2}{2}p^2= 2p- 2p^2+ p^2= 2p- p^2= k
In general, that is an m+n degree polynomial in p and you are not going to find any explicit formula for the solution of such a polynomial.
which is
mm let me understand better...you are talking about a polynomial in p, but I told that p is known! my incognita is m... did I miss something?
Sorry, for some reason I thought you had said "p". But because the m occurs both in the binomial coefficient and in the exponent, I would say that there is much less likely to be an explicit formula for m.
mm ok! :)
do you see another way to calculate m (or an approximated value)??
It's ok for me to get the minimum value of m that satisfies:
g(n,m,p)>=k
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
