What Happens to Wave Measurements When You Sail at the Speed of Light?
The discussion centers on a thought experiment involving wave measurements from a stationary boat and the implications of sailing into the waves. The original hypothesis suggests that sailing at the same speed as the wave results in a perceived doubling of wave speed, halving the wavelength and doubling the frequency. However, responses clarify that this reasoning reflects the classical Doppler effect and that the speed of light's constancy cannot be derived from water wave behavior. It is emphasized that the wavelength does not change for the observer, and the key variable that alters is the frequency. The conversation concludes with an acknowledgment of the complexities involved in understanding wave behavior and relativistic effects.
Gaz
Hi I want to create a thought experiment involving waves of any kind. I am going to create a thought experiment I am on a boat that is at rest in the ocean. I am standing on the boat measuring the size of the waves and the frequency. So I measure the wave along the side of my boat to have a length of 6 meters and a frequency of 1 per second. So i deduce the wave is traveling at 6 m/p/s (6 meters per second).
Now I sail my boat at 6 m/p/s into the waves what is the outcome ?
My Hypothesis is I would see the waves passing me by at twice the speed so the wavelength is 3 m/p/ half s (3 meters per half second) and as the wavelength half's the frequency doubles to 2 per second.
So I conclude when you measure a wave you cannot add your speed to the wave as your motion has to be added or deducted from the wavelength which will effect the frequency and that is why the speed of light is constant to all observers. Any speed added by your motion is simply deducted from the wavelength and added to frequency. So the speed of light remains the same regardless of your motion. And it is not time that changes?
Gaz said:
as the wavelength halves
Why would the wavelenght be different ? Would the wavelength double if you go in the opposite direction ?
First, what you are describing is called the classical (non-relativistic) Doppler effect. If you read about it, in any standard physics textbook, you will see where you are missing the point.
Second, you made a big leap when you concluded that the speed of light is the same for all observers, by the strength of your argument, which is based on material (water) waves. The speed of water waves is not the same for all observers. You should know that there is no explanation for the speed of light being the same for all (inertial) observers. It is an axiom, the truth of which is borne out by the success of experiments.
Likes davenn
so as the other two have suggested, the wavelength isn't changing, and for you nor is time
so that leaves one choice for what is changing ... can you think what that is and why ?
You have answered it without realising :wink:
Dave
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
