Exploring the Mystery of the De Broglie Wavelength
In summary, Jake says that the de Broglie wavelength is not related to the size of the particle, only to its momentum. He goes on to say that all elementary particles, including electrons, quarks, etc are point particles, and that the size of the de Broglie wavelength is determined by the size of the particle and the monochromaticity of the waves.
jaketodd
Why is the de Broglie wavelength sometimes larger than the particle it describes?
Thanks,
Jake
Thanks,
Jake
Because that's what QM (the most successful physical theory to date) predicts, and those predictions agree with experiments.
Also for some particles (i.e. electrons & neutrinos), there is no known "size" that can be associated with the particles themselves, so if the de Broglie wavelength is measurable, then it is automatically "larger" than the particles.
If you have cold (i.e. little momentum) big molecules/ atoms, than for example Broglie wave length will exceed the size of the particle.
Should the particle size be the de Broglie wavelength, or does only part of the wavelength exist at a time (what can fit inside the particle's diameter)?
Jaketodd, There were two points made in the responses above that bear repeating. One, that the de Broglie wavelength h/p is not related in any way to the size of the particle. Only to its momentum, and is a measure of how localized its wavefunction is. Two, that all elementary particles including electrons, quarks, etc are, to our best knowledge, point particles.
So is a particle's wavefunction size/localization the size of the de Broglie wavelength?
Thanks,
Jake
Please let us know what a "size of a particle" could be.
Radiocrystallographists use the width of X diffraction rays to evaluate the size of the diffracting crystallites. So clays give broad diffration peaks on a Debye-Scherrer diffractograms, though silts give fine peaks. I could confuse in justice an international crook by such facts. To give precise spots or peaks, the Bragg law demands large crystallites, and monochromatic waves, so with long and broad spindle of each incident quanton, photon or neutron or electron.
For instance, we obtained broad spots by diffracting electrons on a carbide inclusion in a Laue diffractogram, in a Siemens electronic microscope. The monochromaticicty of the electrons was not so perfect, and maybe the carbide inclusion was not a so perfect crystal.
When you write or say "size of a particle", you surrepticiously mean that it is or can be a corpuscle. But where are the experiments that could support such a postulate ?
A little more has to be known : the broglian period, frequency and when moving the broglian wavelength, suffice when an electron interferes with itself - in an Aharanov-Bohm experiment, for instance.
But when an electron interferes whith electromagnetic fields, a photon for instance in a Compton scattering, then the intervening period is the Dirac-Schrödinger, [itex]\frac{h}{2mc^2}[/itex], half of the broglian one. So is the wavelength, too.
But when an electron interferes whith electromagnetic fields, a photon for instance in a Compton diffusion, then the intervening period is the Dirac-Schrödinger, [itex]\frac{h}{2mc^2}[/itex], half of the broglian one. So is the wavelength, too.
This is the second time you have mentioned "Compton diffusion" ... the context seems to suggest you mean "Compton scattering" .. is that correct? I think in French, the word for scattering might be "diffusion", however in English, diffusion has a different meaning in the context of physics.
Thank you for correcting my english. You are right.
No problem .. I didn't think there was any such thing as "Compton diffusion", but I wasn't completely sure, so I figured I check.
Also, I should have done this before: Welcome to PF!
Thanks for the welcome.
It is a pleasure to exchange in a so cooperative spirit.
I came here because of a cross reference to the thread initiated by Ruth Kastner.
I am among those who rediscovered independently the TIQM, but I came far later than John G. Cramer. Anyway I was the first to give a first approximation of the diameter of Fermat's spindle between emitter and absorber. An approximation which could be much more rigourous.
I think in french, then translate, and the results may be so-so... My english has rusted, in the meantime.
Related to Exploring the Mystery of the De Broglie Wavelength
1. What is the De Broglie wavelength?
The De Broglie wavelength, named after French physicist Louis de Broglie, is the wavelength associated with a moving particle. It is a fundamental concept in quantum mechanics and is expressed as λ = h/mv, where λ is the De Broglie wavelength, h is Planck's constant, m is the mass of the particle, and v is its velocity.
2. How is the De Broglie wavelength related to the wave-particle duality?
The De Broglie wavelength is a key concept in the wave-particle duality theory, which states that particles (such as electrons) can exhibit both wave-like and particle-like behavior. The De Broglie wavelength relates the particle's momentum (p) to its wavelength (λ) through the equation λ = h/p. This duality is a fundamental principle in quantum mechanics and has been experimentally verified.
3. What is the significance of the De Broglie wavelength in atomic and subatomic particles?
The De Broglie wavelength plays a crucial role in understanding the behavior of atomic and subatomic particles. It explains why electrons can exhibit wave-like properties, such as diffraction and interference, which are typically associated with waves. It also helps to explain the stability of atoms and the periodic table, as the De Broglie wavelength determines the allowed energy levels of electrons in an atom.
4. How is the De Broglie wavelength experimentally determined?
The De Broglie wavelength is typically too small to be directly measured in experiments. However, it can be indirectly measured using diffraction and interference techniques, where the particle's wavelength can be inferred from the resulting interference pattern. For example, in the double-slit experiment, the distance between the slits and the distance between the slits and the screen can be used to calculate the De Broglie wavelength of a particle passing through the slits.
5. How does the De Broglie wavelength relate to Heisenberg's uncertainty principle?
The De Broglie wavelength is closely related to Heisenberg's uncertainty principle, which states that it is impossible to know both the position and momentum of a particle with absolute certainty. This is because the De Broglie wavelength is inversely proportional to the particle's momentum, meaning that the more precisely we know the momentum of a particle, the less we know about its position. This uncertainty is a fundamental property of quantum systems and has far-reaching implications in understanding the behavior of particles.
  • Quantum Interpretations and Foundations
