How can checking your answer prevent losing marks on an exam question?
CheesyPeeps
I've used z* to mean z conjugate.
Given the equation z + 2iz* = 8 + 7i, express z in the form a + ib.
From SQA Advanced Higher Mathematics 2005 Exam Paper
n/a
I substituted a+ib and its conjugate in for z and z*, which, after some rearranging, gave me z =-3-15i.
I am not sure if that's the correct answer, and I'm a bit suspicious of how straightforward that method was. The question is worth 4 marks, which seems an awful lot for not much work. Have I missed something?
Hi CheezePeeps:
I got a different answer than you did. I agree the problem is straight forward, but careless mistakes are possible. Please post the details of how you arrived at your answer?
Regards,
Buzz
Thanks for your reply!
I looked back over my initial working, and there were definitely some careless mistakes made from rushing through the steps too quickly!
I redid the problem, making sure that I didn't cut any corners or make arithmetic errors, and I got z = 2 + 3i.
To get z = 2 + 3i, I equated the real and imaginary parts of the equation after substituting in a+ib and a-ib, then used simultaneous equations to get the values of a and b.
Hi CheezePeeps:
That is the answer I got.
Regards,
Buzz
n/a
One strategy that you should always use is to check your answer by substituting it into the original equation to see if it "works". In an exam setting that is all you can do: no appeal to outside help.
In your case you would soon see that your answer is incorrect.
Likes CheesyPeeps
Good advice! I lost 7 marks out of 100 on the paper this question was from, and most of them were due to arithmetic errors that could've been avoided by using that strategy, so thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
