Calculating Variance: Sample vs Population
The discussion centers on the calculation of variance for sample means versus population variance. A participant expresses confusion about the expression for variance, particularly regarding the formula for the variance of the sample mean, Var(Xbar). It is clarified that Var(Xbar) is equal to σ²/n, not σ²/n², which is only applicable in a specific scenario involving a single observation. The conversation emphasizes that the sample variance is an unbiased estimator of the population variance, and the variance of the sampling distribution of the sample mean is correctly represented as σ²/n. Overall, the key takeaway is that the variance of the sample mean does not involve n² in the denominator under standard conditions.
CAH
Member warned multiple times about not using the homework template
See the photo of the question+ mark scheme!
I don't understand a question on finding an expression for the variance of something...
Attempt at solution: also I worked out c as (3/2) previously, which is correct
Var(U) = (3/2)^2 x Var(Xbar) = 9/4n^2 x a^2/18
I'll attach a photo of this too if it's easier to read, my problem is that I thought var(Xbar) = var(x/n) = 1/n^2 x var(x)
... But they have done var(Xbar) = 1/n x var(x) ...?
Think about this:
<br /> Var\left(\bar X\right) = Var\left(\frac 1 n \sum_{i=1}^n X_i\right) = \frac 1 {N^2} \sum_{i=1}^n Var(X_i)<br />
What happens when you simplify the sum?
Ah I see so it's just sigma^2/n, is this the same for all cases as in, calculating the variance of a sample and estimating a population variance?.. In other words, kinda, will it ever (a level standard) be 1/n^2 x var(x)
Probably a stupid question, just checking
The only time you would have n^2 in the denominator is if you were (for some reason) considering mathematically a single observation X_1 and calculate
<br /> Var\left( \dfrac{X_1}{n}\right) = \dfrac{Var(X)}{n^2}<br />
"is this the same for all cases as in, calculating the variance of a sample and estimating a population variance?"
I'm not exactly sure what you mean by this, so if my response is off-target that's why.
If you've talked about sampling distributions for the sample mean, the expression \frac{\sigma^2}n is the population variance for that sampling distribution. It will never have denominator n^2, since, as long as the distribution being sampled has a variance, the steps shown above apply.
The (sample) variance of a sample is a different beast. Essentially
* if the population variance is \sigma^2, then the sample variance
<br /> s^2 = \dfrac 1 {n-1} \sum_{i=1}^n \, \left(x_i - \bar x\right)^2<br />
* If you refer to the variance of the sampling distribution of \bar x - which is given above - then to estimate that you have two options
a) If you have a single sample, use the sample variance s^2 to estimate the sampling distribution's variance by calculating
<br /> \dfrac{s^2}{n}<br />
b) If you have a large number of samples, all the same sample size, from the same population, then calculate each sample mean and treat those sample means as a new sample. The sample variance of those (call it s_{\bar x}^2) is the estimate of \dfrac{\sigma^2}{n}
So there are several subtleties to wade through, but in none but the one unusual and unrealistic comment I made at the start will \frac{\sigma^2}{n^2} play a role.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
9K
