Expression with levi-civita symbol
The discussion centers on simplifying the expression involving the Levi-Civita symbol and a matrix of real numbers. Participants explore the relationship between the expression and determinants, suggesting that it may simplify to a determinant multiplied by a factorial. There is a debate about whether the expression equals zero, with considerations of permutations and their effects on the determinant and the Levi-Civita symbol. Clarifications are made regarding notation and assumptions about the vectors involved. The conversation concludes with insights on the properties of permutations, particularly for n=1.
mnb96
Hello,
during a calculation I got the following term:
\varepsilon^{i_1 \ldots i_n}\varepsilon_{j_1 \ldots j_n} (a_{i_1}^{j_1}\ldots a_{i_n}^{j_n})
where \varepsilon is the levi-civita symbol and a_i^j are real numbers.
Is it possible to simplify that expression?
Mathematics news on Phys.org
Hi mnb96! :wink:
I think you can write it {a_{[i_1 \ldots i_n]}}^{[j_1 \ldots j_n]} :smile:
(or maybe that's out by a factor of 1/n!2 ? :redface:)
?? is that the solution ??
...I was wondering if that expression might perhaps be equivalent to the determinant of something. Any ideas?
waa! I didn't notice that you changed the question a minute before I posted my answer. :cry:
...sorry :) :P
I realized of the mistake later, after re-reading my post :(
I thought about the following: since we have that,
<br /> \varepsilon_{j_1 \ldots j_n} a_{1}^{j_1}\ldots a_{n}^{j_n} = det(A)<br />
then,
<br /> \varepsilon^{i_1 \ldots i_n}\varepsilon_{j_1 \ldots j_n} (a_{i_1}^{j_1}\ldots a_{i_n}^{j_n}) =<br /><br /> =\sum_{k=1}^{n!}sgn(\sigma_k(n))\cdot \varepsilon_{j_1 \ldots j_n} a_{1}^{j_1}\ldots a_{n}^{j_n} =<br /><br /> =\sum_{k=1}^{n!}sgn(\sigma_k(n))\cdot det(A)<br />
where \sigma_k(n) is the k-th permutation on the sequence (1,\ldots,n).
Is that correct?
Isn't that supposed to be zero?!
Hi mnb9! :smile:
(just got up :zzz: …)
I think it's clearer (and better, because it's accurate :wink:) to write it …
<br /> \varepsilon_{j_1 \ldots j_n} a_{1}^{j_1}\ldots a_{n}^{j_n} = det((a_1,\cdots a_n))<br />
then you get
<br /> \varepsilon^{i_1 \ldots i_n}det((a_i_1,\cdots a_i_n))<br />
which is … ? :smile:
if it is true that given (1,...,n) there are always as many odd-permutations as even-permutations, then we get...zero! :) right?
BTW, I have some troubles with your notation det((a_1,\cdots a_n)). What are those a_i ?
I assume they are vectors.
I also assume those a_{i1} and a_{in} are instead the vectors \mathbf{a}_{i_1} and \mathbf{a}_{i_n}
Did I get it right?
Finally, do you know a good source in which I can find useful exercises and tricks about manipulations with this notation?
Hi mnb96! :smile:
I don't think so … doesn't interchanging two indices multiply both the epsilon and the determinant by -1 ?
Yup! :biggrin:
(I couldn't be bothered to write it properly :rolleyes:)
Sorry, no idea. :redface:
tiny-tim said:
Hi mnb96! :smile:
Damn! that's true, whenever we have an odd permutation the determinant should change its sign, but also the epsilon will be -1, so we finally have (crossing fingers): <br /> \varepsilon^{i_1 \ldots i_n}\varepsilon_{j_1 \ldots j_n} (a_{i_1}^{j_1}\ldots a_{i_n}^{j_n}) = n!\cdot det((\mathbf{a}_1, \ldots, \mathbf{a}_n))<br />
...Oh, BTW is it true that "given (1,...,n) there are always as many odd-permutations as even-permutations"? :redface:
(btw, i think we usually use small letter for "btw" :wink:)
Only for n > 1 …
try starting the proof with "if there exists an odd permutation π, then … " :smile:
tiny-tim said:
Only for n > 1 …
Ah...why?
if n=1 we have:
<br /> \varepsilon^{i_1}\varepsilon_{j_1}a_{i_1}^{j_1} = \varepsilon^{1}\varepsilon_{1}a_{1}^{1} = a_{1}^{1} = det(\mathbf{a}) = 1!det(\mathbf{a}) = n!\cdot det(\mathbf{a})<br />
I assumed that permuting (1) zero times, means even permutation so that \varepsilon^{1}=+1
That's a different question. :redface:
(and there are no odd permuatations for n = 1 :wink:)
Uhm...I am just wondering if we can just define the levi-civita symbol being equal to 1 in case the sequence has just one element, but that's not terribly important in any case :smile:
This reinforces the fact that the levi-civita symbol cannot be -1 for n=1, but there is no repetition of indices, so it should not even be 0.
