Is Entropy Extensive in an Ideal Solid?
  • Thread starter Thread starter cstang52
    Solid
cstang52
\frac{}{}
Starting from S(E,N)=c(N)+3Nk[1+LN(\frac{E}{3Nh\nu})], derive a version of the Entropy, S(E,N) of an ideal solid that is extensive, that is, for which S(\lambdaE,\lambdaN)=\lambdaS(E,N)
Basically have to prove that S(\lambdaE,\lambdaN)=\lambdaS(E,N).
I can set it up, but I don't know how to eliminate terms to get to a form I can work with.
I have it setup like this:
S(λ E,λ N)=λ S(E,N)
c(λN)+3(λN)k[1+ln\frac{λE}{3(λN)h\nu}]=λ{c(N)+3Nk[1+ln\frac{E}{3Nh\nu}]
But 1. I don't know how to reduce the left side, and
2. when I distribute λ through the right side, is it on everything ending up looking like this: c(λN)+λ(3Nk)[λ+ln\frac{λE}{λ(3Nh\nu)}]? Or something else...
There's one too many lambdas in there:
c(λN)+λ(3Nk)[1+ln\frac{λE}{λ(3Nh\nu)}]
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
