F''(x)>0 in [a,b] so f has a maximum at a or b.
  • Thread starter Thread starter peripatein
    Maximum
peripatein
Hi,
I was asked to show that if f''(x)>0 for every x in [a,b], then f has a maximum at either a or b.
The book proves it thus:
If f has a sationary point in [a,b] then that point must be a minimum, as f''(x)>0, hence a maximum must be obtained at either a or b.
If f does not have a stationary point in [a,b], then f is increasing or decreasing in [a,b] and hence a maximum must be obtained at either a or b.
I don't understand both "hence a maximum must be obtained at either a or b" and "then f is increasing or decreasing in [a,b] and hence a maximum must be obtained at either a or b".
Could someone please clarify?
I believe I've got it, thanks anyway :-)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
