[f(x)'^n continuous at a point (EXAM IN 4 hrs.)
  • Thread starter Thread starter llursweetiell
    Continuous Point
The discussion revolves around proving the continuity of the function g(x) = [f(x)]^n at a point a, given that f is continuous at a and n is a positive integer greater than 1. The original poster seeks to apply the epsilon-delta definition of continuity for this proof.
  • Participants discuss various approaches to proving continuity, including the epsilon-delta definition and composition of functions. Some express uncertainty about the validity of the theorem under certain conditions, while others attempt to clarify the problem statement and the necessary steps for the proof.
There is an ongoing exploration of the proof structure, with some participants providing insights into the necessary conditions for continuity. A few have offered guidance on how to manipulate the expressions involved, while others are questioning the assumptions and interpretations of the problem.
Participants note the importance of the continuity of f at a and the implications for the proof. There is also a discussion about the constraints of choosing delta and how it relates to the epsilon-delta definition.
llursweetiell
Suppose f: D-->R is continuous at a. Let n >1 be a positive integer. using the epsilon-delta definition of continuity, prove g(x)=[f(x)]^n is continuous as a
i know how to do it as a sequence proof; but i don't know how to use the epislon/delta definition to prove it.
i tried using the composition proof too, but that didn't work. any help?
Um, I'm assuming you mean g = f nested n times since you mentioned the "composition proof". If this is the case, I don't even think the theorem is true since if n = 2, you would need f to be continuous at f(a), but f(a) might not even be in D.
the problem states:
suppose f:D--> R is continuous at a. Let n >1 be a positive integer. Using the epsilon and delta definition of continuity, prove g(x)=[f(x)]^n is continuous at a.
Does that help?
Also, the composition way did not work. which is why I'm unsure of how to go about tackling the problem.
Sorry, the comment about the composition of functions threw me off. I should have known that the solvable interpretation is the right one.
Anyways, you need to estimate |[f(x)]^n - [f(a)]^n| knowing that you can bind |f(x) - f(a)| by any positive number. But a^n - b^n has a very nice and symmetric formal factorization, namely
[tex]a^n - b^n = (a-b)(a^{n-1} + a^{n-2}b + ... + b^{n-2}a + b^{n-1})[/tex]
Thus you can replace a with f(x) and b with f(a) to get |[f(x)]^n - [f(a)]^n| equal to |f(x) - f(a)| times a bunch of terms within an absolute value (this is key) as a result of the factorization above. But now can you see what to bind |f(x) - f(a)| by to ensure that |[f(x)]^n - [f(a)]^n| is less than say, epsilon?
So i wrote,
We know that f is continuous at a. to prove that g is continuous at a:
let epsilon be greater than 0 and let delta > 0 such that d=epsilon/[tex](f(x)^{n-1} + f(x)^{n-2}f(a) + ... + f(a)^{n-2}f(x) + f(a)^{n-1})[/tex]
then,
for |x-a| < delta, then |f(x)^n-f(a)^n|=[tex]f(x)^n - f(a)^n = (f(x)-f(a))(f(x)^{n-1} + f(x)^{n-2}f(a) + ... + f(a)^{n-2}f(x) + f(a)^{n-1})[/tex]
< (f(x)-f(a)) * delta = epsilon. So g is continuous at a.
Is that what you meant?
You have the right idea, but you don't actually get to choose delta here. Since f is continuous at a, there is already some delta for which |x-a| < delta implies
[tex]|f(x) - f(a)| < \frac{\varepsilon}{(f(x)^{n-1} + f(x)^{n-2}f(a) + ... + f(a)^{n-2}f(x) + f(a)^{n-1})}.[/tex]
But this is exactly what we need.
QUOTE]
do you mean f(x)^n-f(a)^n < all of the factorization?
Eh, perhaps it would be clearer if I just pieced together the proof. Let epsilon > 0 be given. By the continuity of f at a, there exists some delta > 0 such that |x-a| < delta implies
[tex] |f(x) - f(a)| < \frac{\varepsilon}{|f(x)^{n-1} + f(x)^{n-2}f(a) + ... + f(a)^{n-2}f(x) + f(a)^{n-1}|}.[/tex]
But then
[tex] |f(x)^n - f(a)^n| = |f(x)-f(a)||f(x)^{n-1} + f(x)^{n-2}f(a) + ... + f(a)^{n-2}f(x) + f(a)^{n-1}| < \varepsilon.[/tex]
oh that makes sense. thank you so much! =)
  • · Replies 26 ·
