F95 Compiler Question: Linking & Execution
  • Thread starter Thread starter globox
    Compiler
The discussion revolves around compiling and linking Fortran 95 (f95) code using a software application on Windows 7. The user is unfamiliar with Fortran and seeks guidance on how to compile and link multiple code segments (a.f95, b.f95, c.f95, d.f95, and main.f95) without a provided makefile. Recommendations include using the g95 Fortran compiler, which allows linking all files in a single command or compiling them into object files first. The user also inquires about specific compilation options, such as fixed format source code and promoting REAL type variables to double precision. The conversation suggests checking documentation and contacting the software author for further assistance, given the freeware nature of the software and the absence of direct support.
globox
Hi guys,
I am thoroughly unfamiliar with the fortran, but I have to use a software that based on f95 codes.
In the user manual of the software it says that, this software involves compilation and linking of the following code segments and in the following order:
a.f95
b.f95
c.f95
d.f95
main.f95
... etc.
So, i am using win7 and plato software for the compilation process but i could not figure out the linking and the compilation process.
Can anyone tell me how to link these codes and execute the program?
Or can anyone suggest me another compilation program for f95?
Any help will be appreciated.
Looking forward to hear from you :)
Technology news on Phys.org
Does the software not come with a makefile (or whatever the Windows equivalent is)? If not, you'd probably be better off asking Silverfrost, if you can't find an answer in the documentation. Of course, you might want to contact the author of the software, too.
Yeap the software does not have makefile and as the software is a freeware i do not think that the supplier of the software will help for the execution of the program.
I will check documentation right now, but most probably i will not be able to solve the problem :(
Anyway, thank you
With the freeware (gnu) g95 Fortran compiler I think you can just give it all the files you want to link on the command line. As in,
g95 a.f95 b.f95 c.f95 d.f95 main.f95 -o whatever.exe
Or you can compile the modules a,b,c and d to object files first. As in,
g95 -c a.f95 -o a.obj
and similarly for b,c and d
Then use
f95 a.obj b.obj c.obj d.obj main.f95 -o whatever.exe
ok, another question:
In compiling the codes the following options must be specified:
(1) Fixed format source code (72 columns)
(2) Automatically promote REAL type variables to REAL (KIND = 8)
(double precision)
which fortran software enables specifying the conditions abobe and how?
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I had a Microsoft Technical interview this past Friday, the question I was asked was this : How do you find the middle value for a dataset that is too big to fit in RAM? I was not able to figure this out during the interview, but I have been look in this all weekend and I read something online that said it can be done at O(N) using something called the counting sort histogram algorithm ( I did not learn that in my advanced data structures and algorithms class). I have watched some youtube...
