MHB How can the factor by grouping method simplify polynomials with multiple terms?
  • Thread starter Thread starter mathdad
    Grouping
The discussion focuses on simplifying the polynomial 8a^3 + 27b^3 + 2a + 3b using the factor by grouping method. The initial grouping separates the terms into two groups, leading to a factorization of (2a + 3b)(4a^2 - 6ab + 9b^2 + 1). While the grouping approach is valid, it is pointed out that the final expression must maintain equivalence with the original polynomial. A clarification is made regarding the introduction of the +1 in the final factorization. Overall, the factor by grouping method effectively simplifies the polynomial while ensuring all terms are accounted for.
mathdad
Factor 8a^3 + 27b^3 + 2a + 3b.
8a^3 + 2a + 27b^3 + 3b
2a(4a^2 + 1) = Group A
3b(9b^2 + 1) = Group B
(4a^2 + 1)(9b^2 + 1)(2a + 3b)
Correct?
Mathematics news on Phys.org
I would factor as follows:
$$8a^3+27b^3+2a+3b=(2a)^2+(3b)^3+2a+3b=(2a+3b)\left(4a^2-6ab+9b^2\right)+(2a+3b)=(2a+3b)\left(4a^2-6ab+9b^2+1\right)$$
You grouping is valid, however they have no common factors, and so your factored expression isn't equivalent to the original expression.
In your final answer, where did + 1 come from?
Think of it like this:
$$(2a+3b)\left(4a^2-6ab+9b^2\right)+(2a+3b)=(2a+3b)\left(4a^2-6ab+9b^2\right)+(2a+3b)\cdot1=(2a+3b)\left(4a^2-6ab+9b^2+1\right)$$
It's the same as writing:
$$xy+x=x(y+1)$$
Great work!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
