Factor Theorem Question: Find a and b for P(x) as a factor of T(x)
In summary: So ##c = -8## and we have ##2x^3 - 16x + b = (2x - 8)(x^2 + ax +1)##. Therefore ##b = -8##. But the constant term is b in T(x), we can get q from it. Or can we?No, you cannot get q from b because T(x) and P(x) are not equal. T(x) is a cubic polynomial, while P(x) is a quadratic polynomial. The constant term in T(x) does not necessarily correspond to the constant term in P(x).
Rithikha
If the polynomial P(x) = x^2+ax+1 is a factor of T(x)=2x^3-16x+b, find a, b
Let (px+q) be a factor of P(x),
p can possibly be 1 and so can q, according to factor theorem,
Hence, factors (x+1) or (x-1)
P(1) = 0, substituting I got -2 as a and P(-1) =0 , I got 2 as a
If either (x+1) or (x-1) is a factor of P(x), it has to be a factor of T(x),
T(1) = 0, I got 14 as b in both cases.
But the correct answer is a=3,-3 and b=-6,6 respectively.
Hello Rithikha. Welcome to PF !
You want ##\ p\, x +q \ ## to be a factor of ##\ T(x)\ ## rather than ##\ P(x)\ ##.
Your error is in assuming that P(x) has a linear factor with rational coefficients (which you do when you use the rational root theorem).
Instead let y= P(x) and rewrite T(x) in terms of y.
You want ##2x^3-16x + b = (d x + c)(x^2 + ax + 1)##. It is easy to see that we must have ##d = 2##, so we need ##2x^3 - 16 x + b = (2x + c)(x^2 + ax +1)##.
1. What is the Factor Theorem?
The Factor Theorem is a mathematical theorem that states that if a polynomial function has a root (a value of x that makes the function equal to 0), then (x-a) is a factor of the polynomial, where a is the root. This theorem is used to factorize polynomials and solve equations.
2. How do you use the Factor Theorem to solve equations?
To use the Factor Theorem to solve equations, you first need to identify the roots of the polynomial function. Then, you can use the roots to factorize the polynomial by writing it as a product of (x-a) terms. Finally, you can set each (x-a) term equal to 0 and solve for x to find the solutions to the equation.
3. What is the difference between the Factor Theorem and the Remainder Theorem?
The Factor Theorem and the Remainder Theorem are both ways to factorize polynomials, but they have different purposes. The Factor Theorem is used to factorize polynomials and solve equations, while the Remainder Theorem is used to find the remainder when a polynomial is divided by (x-a).
4. Can the Factor Theorem be used for all types of polynomials?
Yes, the Factor Theorem can be used for all types of polynomials, including quadratic, cubic, and higher-order polynomials. However, it can only be used to factorize polynomials with real or complex coefficients.
5. Are there any limitations to using the Factor Theorem?
One limitation of the Factor Theorem is that it can only be used to factorize polynomials with rational roots. It cannot be used to factorize polynomials with irrational or imaginary roots. Additionally, the Factor Theorem can only be used to factorize polynomials with real or complex coefficients, so it cannot be used for polynomials with other types of coefficients, such as vectors or matrices.
