Factors affecting the internal energy
The identity of molecules significantly affects their internal energy, alongside temperature and volume. Different molecular structures, such as carbon dioxide versus water, have distinct bond energies that influence chemical reactions. Variations in isotopes, like regular water versus heavy water, also lead to different nuclear bonding states and energy levels. However, when comparing identical molecules with the same atomic configuration and external conditions, their internal energy remains the same. Understanding these factors is essential in fields like chemistry and nuclear physics.
weng cheong
does the identity of molecules affect the internal energy, besides the temperature and volume?
By identity, I assume you mean for instance a carbon dioxide molecule versus a water molecule. If so, then yes, the stored energy depends quite strongly on identity. Much of chemistry is the prediction and understanding of the different molecular bond energies, because they determine if and how reactions take place.
If by identity you mean the same chemically, but different nuclear-wise, such as water versus heavy water, then the answer is still yes. There are different nuclear bonding states and thus different energies in the different elemental isotopes. Nuclear physics studies these different energies, and understanding them is crucial to design of nuclear weaponry and power plants.
If by identity you mean two water molecules with atoms of the same isotope, experiencing the same external environment, and having their electrons in the same configuration, then the answer becomes no. Beyond atomic type and arrangement, isotope configuration, and electron states, molecules do not have an identity. One water molecule is the same as the next.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
