Failing point of a lexan spheres?
The discussion addresses the safety concerns of calculating the failure points of lexan spheres submerged in seawater. Key calculations sought include the depth at which the spheres would implode, the height from which they could be dropped without failing, and the weight needed for neutral buoyancy. Additionally, the user inquires about the relationship between internal stress and the spheres' pressure resistance. The thread concludes with a warning that projects involving potential life-safety risks should be handled by a professional engineer.
aussie101
Hi
I'm a newby and have a project way out of my depth where a wrong calculation will be fatal...
I need calculations of :
1.how far a 2500mm and 3000mm sphere of lexan plastic 50mm thick can be submerged in sea water before it will implode/fail (in meters)? See data below.
2.From what height can the either sphere be dropped from onto the sea water surface tension before failing?
3.How much weight (kg) would it take to make the spheres neutrally buoyant (neither sink or float)?
4.Can the stress formed in process (inside the sphere) be calculated and ratio to the above calcs? (e.g. For every mpa stress in structure will reduce the mpa of impak or pressure resistance/rating)
MECHANICAL
Tensile Stress, yld, Type I, 50 mm/min 590 kgf/cm²
Tensile Stress, brk, Type I, 50 mm/min 580 kgf/cm²
Tensile Strain, yld, Type I, 50 mm/min 5.7 %
Tensile Strain, brk, Type I, 50 mm/min 117.9 %
Tensile Modulus, 50 mm/min 23000 kgf/cm²
Flexural Stress, yld, 1.3 mm/min, 50 mm span 960 kgf/cm²
Flexural Modulus, 1.3 mm/min, 50 mm span 22900 kgf/cm²
Tensile Stress, yield, 50 mm/min 57 MPa
Tensile Stress, break, 50 mm/min 56 MPa
Tensile Strain, yield, 50 mm/min 5.4 %
Tensile Strain, break, 50 mm/min 119.4 %
Tensile Modulus, 1 mm/min 2340 MPa
Flexural Stress, yield, 2 mm/min 89 MPa
Flexural Modulus, 2 mm/min 2140 MPa
IMPACT
Izod Impact, notched, 23°C 75 cm-kgf/cm
Izod Impact, notched, -30°C 63 cm-kgf/cm
Instrumented Impact Total Energy, 23°C 763 cm-kgf
Izod Impact, notched 80*10*4 +23°C 47 kJ/m²
Izod Impact, notched 80*10*4 -30°C 24 kJ/m²
Charpy 23°C, V-notch Edgew 80*10*4 sp=62mm 61 kJ/m²
Charpy -30°C, V-notch Edgew 80*10*4 sp=62mm 17 kJ/m²
You are not going to get help here with projects that could have life-safety implications. You need to engage a professional engineer to help with projects like that.
Thread closed.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
9K
