This thread discusses the calculation of angular velocity for a falling object simulation, focusing on the relationship between potential energy (PE) and kinetic energy (KE) as the object falls from a vertical position to a horizontal position. Participants explore various methods to derive angular velocity at different angles and how to implement these calculations in a simulation environment.
- Homework-related
- Technical explanation
- Debate/contested
- One participant outlines their approach to calculate angular velocity (ω) by using the difference in potential energy between angles and equating it to kinetic energy.
- Another participant questions the validity of using ΔPE = KE, suggesting it should be ΔPE = ΔKE instead, leading to a discussion on the correct formulation of energy conservation in this context.
- There is a proposal to calculate angular velocity at each degree of rotation, starting from 90° to 0°, and to store these values for simulation purposes.
- Concerns are raised about the accuracy of the angular velocity values, particularly regarding expected acceleration patterns during the fall.
- Participants discuss the need for initial conditions and how they affect the simulation, particularly when starting from a position of equilibrium.
- One participant shares a simulation link to illustrate their findings and the resulting graph of angular velocity over time.
- There is a suggestion to numerically solve the equations of motion to derive angular velocity as a function of angle, with a focus on the relationship between angular displacement and time in the simulation.
Participants express differing views on the correct application of energy conservation principles, particularly regarding the use of ΔPE = KE versus ΔPE = ΔKE. The discussion remains unresolved as participants explore various methods and interpretations without reaching a consensus.
Some participants highlight the importance of initial conditions and the potential for misinterpretation in energy calculations. There are also mentions of the need for clarity in the simulation parameters and the representation of angular velocity over time.
