Fan and Filter Seperation Dist.?
  • Thread starter Thread starter James3849
    Fan Filter
The discussion focuses on designing ventilation for pump stations in a water pipeline project, emphasizing forced air cooling without air conditioning. A key concern is the arrangement of fans and air filters, with recommendations suggesting filters should be placed at least 1.5 times the fan diameter away for optimal airflow. Participants mention that industry practices often suggest a distance of 3 to 8 pipe diameters to ensure flow uniformity. The inquiry seeks formal standards or credible manufacturer resources to support these guidelines. Proper fan and filter separation is crucial for effective ventilation design.
James3849
Hi,
I'm currently designing the ventillation for a number of pump stations for a large water pipeline. Essentially this will mainly involve forced air cooling, to keep the space within 5degress of ambient (i.e. no air conditioning).
My question has to with fan and and air filter arrangements. Through some brief reading I have found some 'rules of thumb' saying that the filter should be placed away from the fan at a distance of at least 1.5 x fan diameter, for uniformity of air flow through the filter.
Does anyone know any formal standards or industry guidelines that specify this. Or even websites of manufactures that look more legit. than the one's I've found
I am not sure of formal standards, but often 3 to 8 pipe diameters are used to straighten the flow for something like this.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
