Faraday's law of mutual induction
This discussion focuses on Faraday's law of mutual induction, specifically the selection of surfaces for calculating electromotive force (emf). The boundary of the chosen surface must be the loop around which the emf is computed, typically a flat, orientable surface to simplify calculations. An example provided involves a circular loop of wire with a radius of 1 cm placed inside a solenoid, where the magnetic field increases to 0.1 T over 0.001 seconds. The resulting emf calculated is 0.031 V, producing a current of 31 mA, which is safe for the LED in the circuit.
  • Understanding of Faraday's Law of Induction
  • Familiarity with magnetic flux concepts
  • Basic knowledge of circuit components, including resistors and LEDs
  • Ability to perform calculations involving magnetic fields and emf
  • Study the derivation of Faraday's Law and its applications in electrical engineering
  • Learn about the properties of orientable surfaces in electromagnetic theory
  • Explore examples of mutual induction in different circuit configurations
  • Investigate the effects of changing magnetic fields on various circuit components
Students of physics, electrical engineers, and anyone interested in understanding electromagnetic induction and its practical applications in circuit design.
darksyesider
When solving for mutual induction, how do you know what surface to take the flux over?
You are allowed to choose any surface* as long as its boundary is the loop around which you are computing the emf. In general you choose a flat surface if that's possible, so as to make calculations easier, but you could choose whatever surface you like as long as it has the right boundary.
* okay, not quite any surface -- you have to choose an orientable surface, but you don't need to worry about that unless you are deliberately being perverse.
So you ALWAYS make the boundary the loop where you're computing the emf?
Can you think, by any chance, of an example of this? (besides coaxial cables which i made a post about a few days/hours ago)
Yes, the loop around which you are computing the emf must always be the boundary of the surface.
If you are confused about this, I would suggest that you watch Walter Lewin talk about it (start at 5:00) if you haven't already.
As for an example, basically any Faraday's Law problem will do the trick.
Here's an example: A circuit consisting of a circular loop of wire (radius 1 cm) and an LED is placed inside a solenoid, with the loop of wire concentric with the coils of the solenoid. The solenoid is turned on and the magnetic field inside smoothly increases to 0.1 T over 0.001 seconds. The LED has a 1 ohm resistance and will explode if a current greater than 50 mA flows through it. Does the LED survive?
Answer: We want to calculate the EMF of the circuit, so the circuit has to be the boundary of my surface. I choose the flat surface, which is just a circle, and in this case I am in luck -- the magnetic field is perpendicular to that surface. So the magnetic flux is BA. The rate of change of magnetic flux is 0.1 T * pi(0.01 m)2/0.001 s = 0.01*pi Tm2/s. Therefore, the emf is 0.031 V, which produces a current of 31 mA. That is not enough to explode the LED.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 25 ·
