Faraday's Law not obvious to me
In summary, an emf is generated in the outside coil of the solenoid when a current is applied, even though there is no magnetic field present at any time. This is similar to a transformer, where the dB/dt is limited to the iron core, and the coil represents the windings outside the iron.
Wannabeagenius
91
Hi All,
Please take a very long tightly wound solenoid of any radius with another coil wound around the outside of it. Now, if a current is applied to the solenoid, the changing flux of the magnetic field causes an induced emf in the outside coil which is perfectly consistent with the math of the situation.
Although the math is perfectly obvious to me, I don't understand how such a thing could happen. The wire in which the emf is generated is in a part of space where absolutely nothing happens. Put the whole set up in a vacuum and the wire is then in a part of space where there is absolutely nothing!
How could such a thing happen?
Thank you,
Bob
A changing magnetic flux induces an electric field that propagates outward so that it may induce a current through the outer coil.
Thank you. That makes perfect sense.
Bob
To add to what Wannabeagenius says, a changing current in the solenoid causes changing electric and magnetic fields external to the solenoid that propagate radially at velocity c.
Wannabeagenius said:
Hi All,
Thank you,
Bob
It's a good question, particularly if the solenoid is infinitely long (so that B = 0 at all external points). The key here is that the vector potential is NOT zero at points external to the solenoid. It circulates around the solenoid's axis, and the circulation equals B inside the solenoid. The existence of a time-varying vector potential circulation is equivalent to a time varying magnetic field inside the solenoid. An emf is induced in the outer coil, even though B=0 at all times outside of the solenoid!
An emf is generated in the coil because there is a net
EMF = -N∫(dB/dt)·n dA inside the coil (and inside the solenoid). (Faraday's Law).
This is identical to a conventional transformer, where the dB/dt is confined to the iron core, and the coil represents the windings outside the iron.
Bob S
Bob S
I've had enough of reposting blown-out posts from a bad internet connection, containing all the supporting equations. So simply put, there is no required action at a distance influences from magnetic fields interior to both an idealized infinite solenoid and interior to the iron of a transformer that produced a current flow in exterior windings.
A changing current in either one results in exterior electric and magnetic fields that obey the harmonic equations of traveling and attenuated waves in a vacuum with appropriate boundry conditions at the surface of the solenoid or core material.
If I am lucky, and short winded, this will post the fields surrounding an ideal solenoid.
[tex]\partial_{r}{}^{2}E_{\theta}(r) = \frac{1}{c^2} \partial_{t}{}^{2} E_{\theta}(r)[/tex]
[tex]\partial_{r}{}^{2}B_{z}(r) = \frac{1}{c^2} \partial_{t}{}^{2} B_{z}(r)[/tex]
An example (because it was the easiest to solve.), is a constantly increasing current in an ideal solenoid.
[tex]E_{\theta}(r)= E_{r_0} \exp[(-r+ct)/R][/tex]
[tex]B_{z}(r) = B_{r_0} \exp[(-r+ct)/R][/tex]
1. How does Faraday's Law relate to electromagnetic induction?
Faraday's Law is a fundamental principle in electromagnetism that describes the relationship between a changing magnetic field and an induced electric field. It states that when a magnetic field passing through a conductor changes, an electric current will be induced in the conductor.
2. What is the mathematical equation for Faraday's Law?
The mathematical equation for Faraday's Law is E = -N(dΦ/dt), where E is the induced electromotive force (EMF), N is the number of turns in the coil, and dΦ/dt is the rate of change of the magnetic flux through the coil.
3. How is Faraday's Law used in everyday technology?
Faraday's Law is used in everyday technology such as generators, transformers, and electric motors. It is also the basis for many modern technologies, including wireless charging, magnetic levitation, and electromagnetic induction cooking.
4. Why is Faraday's Law important in understanding electromagnetism?
Faraday's Law is important in understanding electromagnetism because it explains the relationship between electricity and magnetism. It also forms the basis for many other important laws and principles in electromagnetism, such as Lenz's Law and Maxwell's equations.
5. How did Faraday's Law contribute to the development of modern physics?
Faraday's Law played a crucial role in the development of modern physics. It provided a fundamental understanding of the relationship between electricity and magnetism, which led to the development of electromagnetism and the electromagnetic spectrum. It also paved the way for the discovery of other important laws and principles in physics.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
