Farthest distance a human can travel from Earth in a life
The discussion revolves around the theoretical limits of how far a human could travel from Earth in a lifetime, considering factors such as acceleration, time dilation, and relativistic effects. Participants explore the implications of constant acceleration and the equations governing such scenarios, particularly in the context of special relativity.
  • Some participants propose that the farthest distance a human could travel is determined by the acceleration a human can withstand and the length of their life, specifically under constant acceleration of 9.8 m/s².
  • Others argue that classical equations for displacement do not adequately address the relativistic nature of the problem, emphasizing the need to consider time dilation and length contraction.
  • A participant mentions that using the relativistic rocket equation could yield distances on the order of 10^22 light years without considering the expansion of the universe.
  • Another participant claims that if one accelerates at 1g for 100 years without stopping, the distance covered could be approximately 3*10^11 light years, but this also requires general relativity corrections.
  • Some participants express confusion about the implications of ignoring the speed of light limit in their calculations, with one noting a mental error regarding the speed achievable in 100 years.
  • There are differing calculations presented, with one participant asserting a distance of about 2.6 * 10^44 light years, while another participant claims to have a different answer after double-checking their work.
  • Several participants reference external resources, such as the Usenet Physics FAQ article on the relativistic rocket equation, as helpful for understanding the problem.
Participants do not reach a consensus on the correct approach or final answer to the problem. Multiple competing views and calculations are presented, leading to ongoing debate and uncertainty.
Limitations include the need for clarity on how distances are measured in relativistic contexts, the potential impact of the universe's expansion, and the unresolved mathematical steps in deriving the distances discussed.
This discussion may be of interest to those studying physics, particularly in the areas of relativity, space travel, and theoretical limits of human exploration in the universe.
James Horner
I've been stuck on this physics problem for several years now. I would be very grateful if someone could explain how to solve this problem. The farthest a human could travel from Earth in one lifetime theoretically is limited only by the acceleration a human can withstand, and the length of their life. Solving the problem below would answer this question, taking into account relativity.
A spaceship starts at rest on Earth, ignoring gravity. The spaceship then accelerates, and from the perspective of the astronauts inside the spaceship, it appears to accelerate at a constant 9.8 m/s^2. After the astronauts on the spaceship get 100 years older, how far away will the spaceship be from the perspective of Earth?
If you want to keep this simple and ignore the maximum physically possible velocity of the spaceship, then this can be easily solved using a displacement equation:
Δx=v0Δt + (1/2)aΔt2
where
Δx is displacement
v0 is initial speed
a is acceleration
Δt is time elapsed
I understand classical acceleration equations, my question is how far the spaceship would be taking into account time dilation, length contraction, ext...
In other words, ignore the fact that the ship can't go faster than light? What's the point of ignoring the actual laws of physics that apply to the problem?
The best quick resource is the Usenet Physics FAQ article on the relativistic rocket equation:
http://math.ucr.edu/home/baez/physics/Relativity/SR/Rocket/rocket.html
It has everything you need.
Try googling for "The Relativistic Rocket", for example <<this link>>.
In 28 years, if you don't want to stop, you can reach Andromeda, accelerating at 1g.
In 100 years, if you don't slow down to stop at the destination, using the special relativistic (SR) formula, I make the distance you cover to be on the order of 10^22 light years. But you'd undoubtedly need to take into account the expansion of the universe as the FAQ mentions, and I don't see any discussion of the needed formula to do this. And it would be tricky to work it out correctly, amongst other issues one would need to be clear on how the distance was being measured in the first place.
Using the same SR formula, if you wanted to stop at the destination, the distance you'd cover in 100 years would be on the order of 3*10^11 light years or so. Again, this doesn't have the needed GR corrections.
(add) As peter mentioned (he types faster), the SR number DOES take into account the speed-of-light limit, and other relativistic effects such as time dilation. As you'll probably notice, the distance you can cover according to SR is considerably larger than the distance you could cover in a Newtonian model.
A simple mental error led me to believe it couldn't reach light speed in 100 years. Indeed, I was wrong, as the speed reached would be about 3.09E10 m/s.
As a rule of thumb, a 1 g acceleration means getting close to light speed in about 1 year. The time varies inversely with the acceleration, so a 100 g acceleration would mean getting close to light speed in about 1/100 of a year (or a few days), and a 0.01 g acceleration (within range of today's ion drives) would mean getting close to light speed in about 100 years.
The article is very interesting!
Δx=v0Δt + (1/2)aΔt2
where
Δx is displacement
v0 is initial speed
a is acceleration
Δt is time elapsed
That is a useless answer because this problem is extremely relativistic. The answer is about 2.6 * 1044 light years. See:
PeterDonis got it covered.
I get a different answer than Pervect. I've double checked mine and it seems right.
Thanks for the help, the relativistic rocket is a really helpful article. I'm still trying to figure out which exact equation describes the distance as a function of acceleration and time.
It's the equation for ##d## (lower case) in terms of ##a## (the acceleration) and ##T## (upper case--that's the time according to the crew of the rocket).
I agree with your answer$$
\frac{\cosh(103) - 1}{1.03} = 2.62 \times 10^{44} \text{ light years}
PAllen said:
That is a useless answer because this problem is extremely relativistic. The answer is about 2.6 * 10^44 light years. See:
cosh(103)−11.03=2.62×10^43 light years​
There is a slight difference between your answers. Did you both solve it a different way or something of the sort?
Sorry, I made a typo which I have now corrected. 44 not 43.
Oh okay I see now.
That sounds almost like something doable with present technology and some gaffer tape!
Quick question: what equation is this that you used (I understand the hyperbolic cosine part just not the whole thing)? Is it related to the Tsiolkovsky rocket equation?
Peter already answered this in post #13. Everything you need to check this is that equation and constants in useful units provided in that rocket article. If you do the google search Pervect suggested, you will also find several links to derivations of the relativistic rocket equations from first principles.
I'm not sure where I went wrong, but if Peter & Dr. Greg both get different answers, I probably made an error somewhere.
It was actually PAllen who posted the same answer as DrGreg, but I'll quickly run through a sanity check. An acceleration of 1 g is nice because it equates to almost 1 in units of years and light years (as the Usenet Physics FAQ article notes, 1 g = 1.03 lyr/yr^2). So we can rewrite the equation for ##d## in a much simpler form:
d = \cosh T - 1
since both ##c^2 / a## and ##a / c## are approximately 1. So we just need to evaluate ##\cosh 100 - 1##. The ##1## will be negligible, and my calculator says ##\cosh 100 = 1.344 \times 10^{43}##. This will be the distance in light-years that can be reached in 100 years of ship time.
That is for a journey where we don't want to stop at the destination. If we do, we need to cut ##T## in half, since we will have to spend half our time accelerating and half our time decelerating; then we multiply ##d## by two for the two legs of the journey. So we will have
d = 2 \left( \cosh \frac{T}{2} - 1 \right)
This gives (the 1 is still negligible) ##2 \cosh 50##, which my calculator says is ##5.185 \times 10^{21}## light-years.
DrGreg and PAllen got slightly larger answers because they used 1.03 for the acceleration instead of the 1 I used here as an approximation, which increases the argument of ##\cosh## enough to increase the answer by about an order of magnitude. So their answers look correct to me.
  • · Replies 19 ·
  • · Replies 36 ·
  • · Replies 36 ·
12K
  • · Replies 75 ·
  • · Replies 24 ·
