Maximizing Data Transfer Speed: How to Achieve 480 Mbit/s with USB 2.0
USB 2.0 can theoretically achieve data transfer speeds of 480 Mbit/s, but practical limitations often hinder this performance. The discussion highlights that the operating system may not support these speeds effectively, suggesting that custom hardware solutions might be necessary for optimal data transmission. A proposed method involves using a variable frequency oscillator and high-speed RAM to manage data flow. Additionally, the conversation emphasizes the importance of managing receive/transmit buffers to prevent data loss. Ultimately, achieving the maximum USB 2.0 speed requires a combination of hardware and software considerations.
rxwontfit
The high-speed (USB 2.0) protocol is capable of 480 Mbit/s.
How can I send data at these speeds!?
This seems like a simple question, but I cannot seem to find a simple answer.
Cheers,
JoAr
I suspect that the capability of the protocol far surpasses the capability of Windows to supply data at that rate. In order to test your idea you may have to construct your own circuit to provide data at the rate you need.
For testing, I'm thinking of a variable frequency oscillator driving a binary counter which provides the addresses for a high speed static RAM. The data from the RAM feeds a high speed parallel to serial shift register. You would use more or less the same setup for receiving the data.
I think it's 480 Mega-BITS per second isn't it? That's 60 Mega-BYTES.
If that's so, a regular 720x480 color video image at 30 fps is a touch over 30 Mega-bytes/sec.
The oft quoted bandwidth numbers of a particular interface are determined by the assembly rate of packets and the packet transmission frequency. It says nothing about the technology that reads the packet buffer.
Skeptic2 is right about the need to develop you own means to clear the receieve/transmit buffers (or registers) while still retaining the contents of the transmitted information.
Practical throughput in a personal computing environment is likely to be strongly limited by this threshold.
I can fill your mailbox at a rate of 50 letters/sec... but how fast can you read them without losing content?
Thank you for your comments so far.
@skeptic & FlexGunship: thanks, but certainly your OS can supply data at rates listed on this page?
http://usbspeed.nirsoft.net/
Furthermore, wireless networks cards - they must interact with the OS in order to pump data out and haul data in at rates of 54 Mbits/s?
@schip666!: yes indeed i said, 480MBits/s not bytes...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
