Few questions different topics
  • Thread starter Thread starter lionely
    Topics
The discussion revolves around finding constants p, q, and r in the equation 2y^2 - 9y + 14 = p(y-1)(y-2) + q(y-1) + r. Initial calculations suggest p = 2 and q = -3, but there is confusion regarding the value of r, with participants debating whether it should be 10, 14, or 15. The second part of the problem involves deducing that (y+1)^4 - y^4 < 4(y+1)^3, which some participants believe is unrelated to the first part. Ultimately, the need for clearer connections between the two parts and accurate calculations for r is emphasized. The conversation highlights the importance of careful expansion and comparison in solving polynomial equations.
lionely
Find the constants p,q and r such that
2y2 - 9y+14 = p(y-1)(y-2)+q(y-1) +r
2) Deduce that (y+1)4 - y^4 < 4(y+1)^3
The attempt at a solution
Well I expanded the right side
and just tried comparing the two equations..
so I got p =2 ,r =10, q=-3
is this the correct way of doing this?
2) (y+1)4 - y^4 - 4(y+1)^3<0
I did this first, now I don't know where to carry it.
p and q are correct but r is wrong.
Are you really supposed to use these values for p q and r to deduce the second part? Because I don't see the connection at all
NO the 2nd part of the question is a totally different question ,sorry. is r 14?
No it's not 14 either. Why don't you write out how you solved for r and we can pinpoint the mistake being made.
For the second part once you've gotten to that point I recommend expanding everything and canceling a lot of large powers of y
I expanded the expression and got py^2 - 3py -12p + qy -q +r
so I just compared it to the equation stated and said p is =2 because there's also a two on the y^2 in the first equation. Then I said since p = 2 the -3py is now -6y and in the equation there was a -9y so q needs to be -3 to get a -3y. the r ,-12p and the -q need to add up to the 14 so is r 35?
That should be a +2p not a -12p
ohh I see it, so r should be 15?!
