DiracRules
- 109
Hi there,
I'm reading Dirac's Principles of QM, but I think I miss something...
1)When he derives the Poisson quantic bracket, he states that u_1v_1-v_1u_1=i\hbar[u_1,v_1] and says that hbar must be real since we introduced the imaginary unit. The thing is, since uv-vu is real, because we are talking about dynamics variable that are real linear operator, this means that [u,v] must be pure imaginary. But that doesn't fit well with what Dirac says a few lines below, where he hypothesizes that [u,v] in QM has the same value than in classical mechanic (and I derive from here that it is real).
What am I missing?
2)Why is so important a representation where the observables are diagonal? And why it is so important to build Schroedinger's representation?
3)I can't follow his derivation of the conjugate transpose of d/dq :
giving that \frac{d}{dq}\left.\psi\right>=\left.\frac{d\psi}{dq}\right>
<\psi\frac{d}{dq}=-<\frac{d\psi}{dq}
he makes these consideration: the conjugate transpose of \frac{d}{dt}\psi>\,\,\mathrm{is}\,\,<\frac{d\bar{\psi}}{dq} and, from the previous equation, <\frac{d\bar{\psi}}{dq}=-<\bar{\psi}\frac{d}{dq} hence the conjugate transpose of d/dq -d/dq.
My question is:why \bar{\frac{d\psi}{dq}>}=<\frac{d\bar{\psi}}{dq}? I thought that \forall |P>, \bar{|P>}=<P|and this gives \bar{\frac{d\psi}{dq}>}=<\frac{d\psi}{dq}
Again, what am I missing?
4) What does it mean that \mathbf{p}=i\hbar\mathbf{d}, where d is the translation operator? Better, what is the physical importance and meaning?
Thank you in advance, more questions coming :D
What am I missing?
