Feynman lectures electric dipole question
The discussion focuses on a challenge with differentiating the potential to derive the z-component of the electric field as presented in the Feynman lectures. The key point is understanding how to take the derivative of the expression involving the potential, specifically the term with r, where r is defined as the square root of the sum of the squares of the coordinates. Suggestions include substituting r into the derivative and applying the chain rule to express the derivative in terms of r. The final goal is to rewrite the expression solely in terms of r after evaluating the necessary derivatives. This approach aims to clarify the differentiation process for better understanding.
axmls
Education Advisor
For some reason, I'm having trouble with what I feel should be a relatively simple derivative to take. Feynman is differentiating the potential to find the z-component of the electric field. He has:
-\frac{\partial \phi}{\partial z} = - \frac{p}{4 \pi \epsilon_0} \frac{\partial }{\partial z} \left(\frac{z}{r^3}\right) = -\frac{p}{4 \pi \epsilon_0} \left(\frac{1}{r^3} - \frac{3z^2}{r^5} \right )
I'm not quite sure how he takes that derivative.
Note that ## r = \sqrt{x^2 + y^2 + z^2} ##. So insert ## \sqrt{x^2 + y^2 + z^2} ## everywhere you see a ## r ##, take the derivative, and then
rewrite powers of ##x^2 + y^2 + z^2## in terms of ##r##. Does that help?
jason
Or apply the chain rule in the initial derivative to get an expression that contains ##\partial r / \partial z##, then evaluate that derivative using ##r = \sqrt{x^2 + y^2 + z^2}##, and finally rewrite the result completely in terms of ##r##.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
