Exploring Light Transmission with Lasers & Optical Fibers
Using lasers with optical fibers is effective due to their monochromatic nature, which allows for precise coupling and efficient transmission. In contrast, white light sources, like halogen or mercury arc lamps, lack the coherence and specific wavelength needed for high-speed data transfer. Various types of fibers, including single-mode and multimode, can accommodate different light sources, but single-mode fibers are typically preferred for their ability to restrict wavebands. While it is technically possible to couple different light sources into fibers, lasers provide better control and accuracy for information transmission. Overall, coherent light sources are essential for complex data communication through optical fibers.
chickenlittle
Why is it that we are able to use a laser beam with optical fiber but not with a white light source?
Science news on Phys.org
We need lights with monowavelength
I'm not sure what you mean- I couple a halogen light and a Mercury arc lamp into a fiber on my microscope.
There are many kinds of fibers- single mode, multimode, light guides, bandgap, polarization-maintaining, etc. etc. etc.
A single-mode fiber is what most people associate with "optical fiber", and single-mode means a single transverse mode, which restricts the waveband. Multimode fibers can support a much broader waveband range, light guides (what I use with the halogen bulb/arc lamp) are not much more than "light pipes", and photonic bandgap fiber is really cool.
There's some technical issues with how to couple the light into a fiber, but it's sort of possible to couple nearly any source to any fiber- what light actually propogates down the fiber will depend on the fiber.
Thank you pixel01 and Andy Resnick. I understand better now :)
Welcome to PF, Chickenlittle.
I have to assume here that you're referring to information transmission. Any kind of light will propogate through an optical fibre, as you can easily see by looking at a fibre optic lamp. A modulated source is needed for any sort of information transfer. You can transmit Morse code just by turning a light bulb on and off. For the complexity of high-speed digital transfer, a coherent source is more readily controllable and more accurate.
It is also much easier to couple light into a fibre (with efficiency) using a laser source that it is with using other types of sources.
Claude.
