Field lines and Coulomb Forces
In summary: Is the force between the charges still the same? Yes, the force is still the same between the charges.
Volcano
147
The field intencity around a little spherical conductor changes with reverse ratio to the square of their distance. Then let us put another little spherical charged conductor in field of first one. The field lines are no more change with the reverse ratio to the square of their distance(they are twisted). Does using the Coulomb force is suitable?
I think no. Do we assume the field unchanged?
As far as I know you can use superposition. Calculate the force of one of the charges first and add it (+) to the force of the other charge.
There are only two charges, so there must be only one force. What will i add to that force?
Let me try to put it differently. If you are somehow 'measuring' the force of a charge, you need to have another charge. A charge doesn't exert a force on thin air ofcourse.
Usually this is done with a fictional test charge with a charge of +1C. (Because this simplifies the force equation).
The force that one charge of q C exerts on this 1C charge is ofcourse:
[tex]F = \frac{1}{4 \pi \epsilon_0} \frac{ |q|}{r^2}[/tex]
If you have two charges, [tex]q_1, q_2[/tex] than the force is the (vector) addition of the two forces:
[tex]\vec{F} = \vec{F_1} + \vec{F_2}[/tex]
If you need an example, try this:
Two equal positive point charges [tex]q_1 = q_2 = 0.2 \mu \text{C}[/tex] are located at x = 0, y = 0.3m and x = 0, y = -0.3m, respectively. What are the magnitude and direction of the total (net) electric force that these charges exert on a third point charge [tex]Q = 4.0 \mu \text{C}[/tex] at x = 0.4m, y = 0 ?Consider the following sketch:
The sketch shows the force (represented in it's x and y components) on Q due to the upper charge [tex]q_1[/tex].
From Coulomb's law the magnitude F of this force is:
[tex]F = \frac{1}{4 \pi \epsilon_0} \frac{|q_1Q|}{r^2} = (9.0 \times 10^9) \frac{(4.0 \times 10^-6)(2.0 \times 10^-6)}{0.5^2} = 0.29 \text{N}[/tex]
(the radius r = 0.5 can be found by using pythagoras theorem)
The components of this force are given by:
[tex](F_{\text{1 on Q}})_x = F_{\text{1 on Q}} \text{cos} \alpha = 0.29 \frac{0.40}{0.50} = 0.23 \text{N}[/tex]
[tex](F_{\text{1 on Q}})_y = -F_{\text{1 on Q}} \text{sin} \alpha = -0.29 \frac{0.30}{0.50} = -0.17 \text{N}[/tex]
The same forces can be calculated for the lower charge [tex]q_2[/tex], however, since the system in question is symmetrical you can see directly that the x-component is identical, while the y-component is the same except in the other direction.
So:
[tex]F_x = 0.23 + 0.23 = 0.46 \text{N}[/tex]
[tex]F_y = -0.17 + 0.17 = 0[/tex]
The total force on Q is in the +x-direction with magnitude 0.46 N.
I hope this helps to answer your question!
It is perfectly correct, and the only way in fact, to use the superposition principle to find the intensity at an arbitrary point given any number of charges or charged bodies, provided you know the intensity due to each charge. Here, since both are spherically symmetric charges, outside the charged bodies their fields are as if each is a point charge. So, to find the intensity at a point, use the vector sum of the individual intensities, as Nick89 has explained.
No, you misunderstood. Add the fields due to each charge to get the resultant field at a point.
Giving the absolute sign and then taking the vector sum is not correct. Leave out the absolute sign on q.
Sorry I should have been more clear there. The [tex]\vec{F_1}[/tex] force does not correspond to the (non-vector) force above. The first formula is the magnitude only, the direction should be obvious because there are only two charges.
(Note the lack of vector arrow above the F in the first equation)
The direction is usually not easy to see directly when you have multiple charges, that's when you use vector addition to find the direction.
Thank you, but I mean a different thing. There are only two charges(little sphere). The force is between them. Let me try one more.
http://i26.tinypic.com/2mwbh37.jpg
http://i27.tinypic.com/35d6ikz.jpg
Above pictures shows the field lines for a spherical charge. As already known, lines go away uniform for the upper link, so we can say [tex]E \propto \frac{1}{{r^2 }}[/tex]. But for second link, it is not uniform as other. Now can we can say [tex]E \propto \frac{1}{{r^2 }}[/tex] also?
As shown above the field twisted and no more changing with reverse ratio to the square of their distance.
Another say, as you may notice, I add circles which surrond charges. Let's choice two different points on circle for first figure. Any one has the same magnitude of electric field. Now let's do the same thing for second(below) figure. Take two different point on second circle(below figure). Are those two magnitude of field the same? I think no.
The force between two charged spherical conductors is given by the Coulomb's law, where the distance between the charges is calculated from the centres of the spheres, as long as they don't overlap or touch each other.
This is true for any spherically symmetric charge distributions, which means that, if there is a spherically symmetric charge distribution within a sphere, then the field outside the sphere is as if the whole charge is concentrated as a point charge at the centre.
How can you say that [tex]E \propto \frac{1}{{r^2 }}[/tex] without using a test charge?
Can you feel the electric field there yourself? Ofcourse you can't.
The only reason you know that [tex]E \propto \frac{1}{{r^2 }}[/tex] is because, if you hold a test charge of 1C at a distance r near the charge you have drawn, than the force the test charge feels is proportional to 1/r².You want to know how this proportionality works when you have 2 charges?
I can't tell you directly, but in the same manner that you can add the forces, you can also add the electric fields at a point. Doing this for multiple points might give you the result you are looking for.
Exactly this.
This is exactly too. I know this is very easy question. And coulomb Law help to calculate the force. When I look at field lines between two charges, asked myself that, how these twisted field lines already do the same thing like the linear lines. Than thought, maybe we assume something when calculate. Honestly very hard thing to explain with another language :redface: by the way here is the best place to learn. Sorry for my weak language but thank you all for help.
1. What are field lines?
Field lines are a graphical representation of the direction and strength of an electric field. They show the path a positive test charge would take if placed in the electric field.
2. How are field lines related to Coulomb forces?
Field lines are directly related to Coulomb forces, as they represent the direction and strength of the electric field, which is created by the presence of electric charges. Coulomb forces are the forces of attraction or repulsion between two electric charges.
3. How do field lines behave around electric charges?
Field lines always begin on positive charges and end on negative charges. They also never cross each other, as this would create contradictory information about the direction of the electric field at that point.
4. What can field lines tell us about the strength of an electric field?
The density of field lines at any given point represents the strength of the electric field at that point. The closer the field lines are together, the stronger the electric field is at that point.
5. Can field lines exist in a vacuum?
Yes, field lines can exist in a vacuum. In fact, electric fields can exist in a vacuum as they do not require a medium to propagate through. Field lines can also exist in other mediums, such as air, water, or even in non-conductive materials like plastic or rubber.
  • Electromagnetism
  • Electromagnetism
