Field of Fractions: Proof it is a Field
In summary: A is a finite subset of a countable infinite set then G is a group. So if D is a finite integral domain and mult_a is injective, then G must be a group.In summary, your proof should probably be inspired by how you would prove that the rational numbers are a field, which is obviously infinite.
beetle2
111
Hi guys,
I know that for integral domains with finte elements that if we show that each element has a multiplicative inverse then it is a field.
I need to show that the field of fractions is a field.
As the domain is not finite how does that effect the proof of being a field?
regards
Brendan
Whether the domain is finite or not will be irrelevant unless you have a pretty wacky proof.
Your proof should probably be inspired by how you would prove that the rational numbers are a field, which is obviously infinite
The definition of a field is an integral domain in which each non-zero element has an inverse. I don't see where you get the finiteness condition from.
So just take an arbitrary non-zero element in the field of fractions and show that it has an inverse.
Is this what you meant by the first question? "If an integral domain is finite then it is a field." This is fairly well-known. To prove it: Suppose x is a nonzero element of a finite integral domain; then find positive integers k > l such that xk = xl. Then prove that xxk-l-1 = 1.
If adriank is correct, and you mean prove A. "If an integral domain is finite then it is a field." and B. "Why does this fail if the integral domain is not finite?" then consider the following:
First, if you have an integral domain D any a (not 0) inside D then the function
mult_a: D --> D given by
mult_a(x) = a*x
is injective -exactly- because D is an integral domain:
mult_a(x) = mult_a(y) => a*x = a*y => x=y by cancellation property of integral domains.
But if is D finite, mult_a is also surjective, so for some x, mult_a(x) = 1. So what does this mean about x?
Second, if D is not finite then you can't conclude anything: the function f: Z --> Z (Z = integers) given by f(x) = 2*x is injective but certainly not surjective, and Z is an integral domain.
Anyways, that an injective function f: A --> A is surjective if A is finite is a very important fact in mathematics. That this can fail if A is infinite is equally important. You can use this last fact to construct a (nontrivial) group G so that G x G is isomorphic to G, for example.
Skolem
1. What is a field of fractions?
A field of fractions is a mathematical concept that extends the idea of fractions to include all real numbers. It is a set of numbers that can be expressed as a ratio of two integers, where the denominator is not equal to zero.
2. How is the field of fractions different from the set of rational numbers?
The field of fractions includes all rational numbers, but it also includes irrational numbers such as pi and square root of 2. This means that the field of fractions is a larger set than the set of rational numbers.
3. What is the proof that the field of fractions is a field?
The proof that the field of fractions is a field involves showing that it satisfies all the axioms of a field. This includes closure under addition and multiplication, existence of additive and multiplicative inverses, and distributive property. Additionally, it must also satisfy the axioms of a commutative ring.
4. Why is the field of fractions important in mathematics?
The field of fractions is important because it allows for the representation of all real numbers, including irrational numbers. This makes it a valuable tool in solving equations and performing calculations involving real numbers. It is also used in many areas of mathematics such as algebra, analysis, and number theory.
5. Can the concept of field of fractions be extended to other number systems?
Yes, the concept of field of fractions can be extended to other number systems such as complex numbers, polynomials, and matrices. In each case, the field of fractions includes all the elements of the original number system and extends it to include additional elements that were previously excluded.
  • Linear and Abstract Algebra
