Describing Coulombian Attraction/Repulsion Using Fields
  • Thread starter DaTario
  • Tags
    Fields
In summary: Clem, thank you for your input. I am going to try the integration method and see if I can get the motion of the charges. In the meantime, I am also going to look into the other two methods. I appreciate your help.
DaTario
1,039
35
Hi All
Does anybody know if there is some formalism according to which we can describe the coulobian repulsion (or attraction) of two point like bodies by just working with its fields.
Notice that in general we are given one particle and one field to solve typically this problem.
Thank you
DaTario
I guess (just now) that minimizing the energy of the superimposed fields of the two particles may lead to the dynamics I am searching for, but I am not 100% sure. I see no mass participation in this approach...
Thanks anyway
DaTario
Um, you have [tex]\mathbf{F} = q\mathbf{E}[/tex], so isn't the repulsive/attractive force already determined by the magnitude and direction of the E-fields?
I guess I was not clear enough.
My point is the following:
Given just two fields, namely:
a) field 1 which is the field of the particle 1, in position 1 at time t=0, which has the mass 1 and the charge 1 (1 is label here) and
b) field 2 which is the field of particle 2, in position 2 at time t =0, having the mass 2 and charge 2,
by just manupulating these two fields (the masses will have to enter in some place..) the dynamics must follow with the field representation, in the sense that we must have a resultant field, that is a function of time, and which represent the field composed by the sum of particle's field located at positions corresponding to the dynamically correct postions in such a coulombian situation like this.
I expect to have made myself clear, but may be I haven't.
Anyway, thank you.
DaTario
Indeed. See, for example, Section 1.11 in the third edition of J. D. Jackson's Classical Electrodynamics.
DaTario said:
Hi All
Thank you
DaTario
Hi DaTario,
just to be clear that I understand your question. You are looking for a formalism for dynamics of charges which is not relying on the established concept of E and B Fields but arising from the fact the same/opposite charges repulse/attract each other ?
Rgds, snapback
1. You can integrate E_1.E_2 over all space to get the potential energy U.
The3n F=-grad U.
2. You can use the .Maxwell stresws tensor.
Each of these methods is in textbooks.
I guess the way pointed out by clem is the one I was suspecting to be The One.
Thank you all
Best Regards
DaTario
Hi clem, I am giving a step back on what I have said. What is E_1 and E_2 in your proposal?
I am looking for a formalism that from two particles fields and from their masses, one receive at the end two vectorial fields which depend on time and reflect the attraction or repulsion of the respective point charges.
best regards
DaTario
E1 and E2 are the electric fields you described:
"a) field 1 which is the field of the particle 1, in position 1 at time t=0, which has the mass 1 and the charge 1 (1 is label here) and
b) field 2 which is the field of particle 2, in position 2 at time t =0, having the mass 2 and charge 2,"
However, finding the force by the two methods I gave in post #7 works only in the static case. If either charge is in motion, the force becomes very complicated because of the retarded time.
I agree with you. But anyway I saw no reference in which one starts from two point like fields of positive charges, for instance, and applying a given formalism ends up with a time dependent field which is the superposition of two point like fields getting far from each other.
There must also be place for magnetism (which will be for certain in Maxwell tensor).
Best wishes
DaTario
You mean a particle submersed in a field.
Yes, all you should know is a function to give you the right intensity of the E.F in space, then you can calculate the force on the charge.
Related to Describing Coulombian Attraction/Repulsion Using Fields
1. What is Coulombian attraction/repulsion?
Coulombian attraction/repulsion is the force between two electrically charged particles. It is based on Coulomb's Law, which states that like charges repel each other and opposite charges attract each other.
2. How is Coulombian attraction/repulsion described using fields?
Coulombian attraction/repulsion can be described using electric and magnetic fields. Electric fields are created by electrically charged particles and exert a force on other charged particles, causing attraction or repulsion. Magnetic fields are created by moving charged particles and can also exert a force on other charged particles.
3. What is the difference between attraction and repulsion in Coulombian forces?
The difference between attraction and repulsion in Coulombian forces lies in the charge of the particles involved. Like charges (positive-positive or negative-negative) will repel each other, while opposite charges (positive-negative) will attract each other.
4. How does distance affect Coulombian attraction/repulsion?
The strength of Coulombian attraction/repulsion decreases as the distance between two charged particles increases. This is known as the inverse-square law, which states that the force is inversely proportional to the square of the distance between the particles.
5. Can Coulombian attraction/repulsion be observed in everyday life?
Yes, Coulombian attraction/repulsion can be observed in everyday life. For example, when you rub a balloon on your hair, it becomes electrically charged and can stick to a wall due to the attraction between the opposite charges on the balloon and the wall. Another example is the force between two magnets, which is also based on Coulomb's Law.
  • Classical Physics
  • Differential Equations
  • Classical Physics
  • Classical Physics
