Fortran File not written after subroutine call
The discussion revolves around a coding issue in a Fortran program where a subroutine call (CALL ZEIGSUB) does not produce any output in the specified unit (NRES) after execution, while other units function correctly. The user shares the relevant code, highlighting the allocation of matrices and the subroutine's structure. A key point of resolution is the identification of a "STOP" statement in the subroutine, which prevents proper execution and output. Replacing "STOP" with "RETURN" resolves the issue, allowing the program to write the expected output to NRES successfully. This change emphasizes the importance of proper control flow in subroutines for successful data handling in Fortran programming.
dilasluis
I'm testing a part of a code and I have a problem. After the subroutine call at line 44 (CALL ZEIGSUB), nothing is written in UNIT NRES. The other units are written correctly. Here's the code:
Fortran:
PROGRAM TEST
IMPLICIT NONE
complex *16, allocatable :: KSTAR(:,:), VR(:,:), CM2(:,:)
real *8, allocatable :: M2(:,:), FREQ(:), MLF(:)
integer *4 :: DOFMECH2, TTT, I, MOI
REAL *8 :: OM, OMM1, TESTOM
REAL(8), PARAMETER :: PI = 4.*datan(1.d+0)
integer *4, parameter :: NRES = 9
open(unit=NRES,file="/Users/ndilokelwaluis/Documents/Fortran/Vibration/MODEL_V1-0/moiresul.dat",status='unknown')
OM = 60
MOI = 3
DOFMECH2 = 4
allocate(KSTAR(4,4))
allocate(VR(4,4))
allocate(M2(4,4))
ALLOCATE(CM2(4,4))
allocate(FREQ(4))
allocate(MLF(4))
KSTAR(1,1) = (-21.10,-22.50)
KSTAR(1,2) = ( 53.50,-50.50)
KSTAR(1,3) = (-34.50,127.50)
KSTAR(1,4) = (  7.50,  0.50)
KSTAR(2,1) = ( -0.46, -7.78)
KSTAR(2,2) = ( -3.50,-37.50)
KSTAR(2,3) = (-15.50, 58.50)
KSTAR(2,4) = (-10.50, -1.50)
KSTAR(3,1) = (  4.30, -5.50)
KSTAR(3,2) = ( 39.70,-17.10)
KSTAR(3,3) = (68.50, 12.50)
KSTAR(3,4) = ( -7.50, -3.50)
KSTAR(4,1) = (  5.50,  4.40)
KSTAR(4,2) = ( 14.40, 43.30)
KSTAR(4,3) = (32.50,46.00)
KSTAR(4,4) = (19.00,32.50)
M2 = reshape( (/ 1.0,1.6,3.0,0.0,0.8,3.0,4.0,2.4,1.0,2.4,4.0,0.0,0.0,1.8,&
                 0.0,4.0 /),(/4,4/) )
CM2 = DCMPLX(M2)
write(NRES,*) 'BEFORE'
CALL ZEIGSUB(KSTAR,CM2,DOFMECH2,FREQ,MLF,VR)
write(NRES,*) 'AFTER'
      DO 1010, I = 1, DOFMECH2
         IF (FREQ(I) .GT. 10 .AND. MLF(I) .GT. 0) THEN
            TTT = I
            GO TO 1020
         END IF
      1010 CONTINUE
      1020 OMM1 = OM
      OM = FREQ(TTT + MOI - 1)
      TESTOM = ABS(OM - OMM1)/OM
      WRITE(NRES,*) 'MOI = ',MOI
      flush(NRES)
      WRITE(NRES,*) 'TEST = ',TESTOM,'FREQ = ',FREQ(TTT+MOI-1),'MLF = ',MLF(TTT+MOI-1)
      flush(NRES)
      close(NRES)
CONTAINS
Fortran:
SUBROUTINE ZEIGSUB(A,B,N,FREQ,MLF,VR)
!     ZGGEV Example Program Text
!     NAG Copyright 2005.
!     .. Parameters ..
      INTEGER          NIN, NOUT,NOUT2
      PARAMETER        (NIN=5,NOUT=6,NOUT2=7)
      INTEGER          NB, NMAX
      PARAMETER        (NB=64,NMAX=4)
      INTEGER          LDA, LDB, LDVR, LWORK
      PARAMETER        (LDA=NMAX,LDB=NMAX,LDVR=NMAX,LWORK=NMAX+NMAX*NB)
!     .. Local Scalars ..
      DOUBLE PRECISION SMALL
      INTEGER          I, INFO, J, LWKOPT
      integer, intent(in) :: N
!     .. Local Arrays ..
      COMPLEX *16,intent(in) :: A(LDA,NMAX)
      COMPLEX *16,intent(out) :: VR(LDVR,NMAX)
      COMPLEX *16      ALPHA(NMAX), B(LDB,NMAX),&
                       BETA(NMAX), DUMMY(1,1),&
                       WORK(LWORK), OM
      DOUBLE PRECISION RWORK(8*NMAX)
      double precision, intent(out) :: FREQ(NMAX),MLF(NMAX)
!     .. External Functions ..
      DOUBLE PRECISION DLAMCH
      EXTERNAL         DLAMCH
!     .. External Subroutines ..
      EXTERNAL         ZGGEV
!     .. Intrinsic Functions ..
      INTRINSIC        ABS
!     .. Executable Statements ..
!      OPEN(UNIT=NIN,FILE="/Users/ee/zggev-ex.d",STATUS="unknown")
      open(unit=NOUT,file="/Users/ndilokelwaluis/Documents/Fortran/Vibration/MODEL_V1-0/fileout.dat",status='unknown')
      open(unit=NOUT2,file="/Users/ndilokelwaluis/Documents/Fortran/Vibration/MODEL_V1-0/fileout2.dat",status='unknown')
      WRITE (NOUT,*) 'ZGGEV Program Results'
!     Skip heading in data file
!      READ (NIN,*)
!      READ (NIN,*) N
      IF (N.LE.NMAX) THEN
!        Read in the matrices A and B
!         READ (NIN,*) ((A(I,J),J=1,N),I=1,N)
!         READ (NIN,*) ((B(I,J),J=1,N),I=1,N)
!        Solve the generalized eigenvalue problem
         CALL ZGGEV('No left vectors','Vectors (right)',N,A,LDA,B,LDB,&
                       ALPHA,BETA,DUMMY,1,VR,LDVR,WORK,LWORK,RWORK,INFO)
         IF (INFO.GT.0) THEN
            WRITE (NOUT,*)
            WRITE (NOUT,99999) 'Failure in ZGGEV. INFO =', INFO
         ELSE
            SMALL = DLAMCH('Sfmin')
            DO 20 J = 1, N
               WRITE (NOUT,*)
               IF ((ABS(ALPHA(J)))*SMALL.GE.ABS(BETA(J))) THEN
                  WRITE (NOUT,99998) 'Eigenvalue(', J, ')',&
                   ' is numerically infinite or undetermined',&
                   'ALPHA(', J, ') = ', ALPHA(J), ', BETA(', J, ') = ',&
                   BETA(J)
                   FREQ(J) = 0
                   MLF(J) = 0
               ELSE
                  OM = ALPHA(J)/BETA(J)
                  WRITE (NOUT,99997) 'Eigenvalue(', J, ') = ',&
                   ALPHA(J)/BETA(J)
                   IF (DBLE(OM) .LE. 0) THEN
                      FREQ(J) = 0
                      MLF(J) = 0
                   ELSE
                      FREQ(J) = SQRT(DBLE(OM))/(2*PI)
                      MLF(J) = AIMAG(OM)/DBLE(OM)
                   END IF
               END IF
               WRITE (NOUT,*)
               WRITE (NOUT,99996) 'Eigenvector(', J, ')', &
                          (VR(I,J),I=1,N)
   20       CONTINUE
! call DSORT (FREQ, MLF, N, 2)
            write(NOUT2,*) 'Ordered EIGENVALUES'
            do 30 J = 1, N
               write(NOUT2,*) 'EIG = ',J,', OM = ',FREQ(J),', MLF = ',MLF(J)
            30 continue
            LWKOPT = WORK(1)
            IF (LWORK.LT.LWKOPT) THEN
               WRITE (NOUT,*)
               WRITE (NOUT,99995) 'Optimum workspace required = ', &
                          LWKOPT, 'Workspace provided         = ', LWORK
            END IF
         END IF
      ELSE
         WRITE (NOUT,*)
         WRITE (NOUT,*) 'NMAX too small'
      END IF
      STOP
99999 FORMAT (1X,A,I4)
99998 FORMAT (1X,A,I2,2A,/1X,2(A,I2,A,'(',1P,E11.4,',',1P,E11.4,')'))
99997 FORMAT (1X,A,I2,A,'(',1P,E11.4,',',1P,E11.4,')')
99996 FORMAT (1X,A,I2,A,/3(1X,'(',1P,E11.4,',',1P,E11.4,')',:))
99995 FORMAT (1X,A,I5,/1X,A,I5)
!      close(NIN)
    flush(NOUT)
    flush(NOUT2)
      close(NOUT)
      close(NOUT2)
      END SUBROUTINE ZEIGSUB
END PROGRAM TEST
THANKS
Technology news on Phys.org
Could it be the STOP you've coded in the subroutine instead of return?
Likes anorlunda
That solved it!
Thanks!
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I have a quick questions. I am going through a book on C programming on my own. Afterwards, I plan to go through something call data structures and algorithms on my own also in C. I also need to learn C++, Matlab and for personal interest Haskell. For the two topic of data structures and algorithms, I understand there are standard ones across all programming languages. After learning it through C, what would be the biggest issue when trying to implement the same data...
