Final temperature of the liquid water?
To determine the final temperature of a 10-kg block of ice initially at -12°C after absorbing 4.15 x 10^6 J of heat, an energy balance approach is required. The heat absorbed must account for both the temperature change from -12°C to 0°C and the phase change from ice to water, using the equations Q=mcΔT for heating and Q=mL for melting. The correct setup involves calculating the heat needed to raise the temperature of the ice to 0°C and the heat required for the phase change, then summing these to equal the total heat absorbed. The user initially struggled with the calculations but ultimately understood the need to consider both the melting of the ice and the warming of the resulting water. The discussion concludes with the user expressing gratitude for the clarification received.
name_ask17
A 10-kg block of ice has a temperature of -12°C. The pressure is one atmosphere. The block absorbs 4.15 106J of heat. What is the final temperature of the liquid water?
Q=mcT
i know i have to find the change from -12 to 0 deg c and then use mLfusion for the ice and add them. i am lost after that. i keep getting the wrong answer. how do i do this?
You'll need to do an energy balance.
Heat absorbed = heat to change phase of the ice + heat to increase the temperature from -12 to T.
you know that heat to change phase of the ice=mLfusion and the heat to increase the temperature = mc(T2-T1).
so would i do Q=mcT+mL as 4.15E6=(10)(4186)(T-12)+(10)(334)? because that is not giving me the correct answer. can you please explain to me what I am doing wrong here?
dont bother. i undersand it now. i was to take the heat gained to ive, ice melting, and water warming up. thank you for your assistance
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
