Find a Bijection [tex]\left[ 0,1 \right] \rightarrow \Re [/tex]
  • Thread starter Thread starter rosh300
    Bijection
The discussion revolves around finding a bijection from the interval [0, 1] to the real numbers R. A proposed function f(r) was initially deemed incorrect due to issues with injectivity and representation of all numbers in [0, 1]. Suggestions included using f(x) = 1/(2x-1) and f(x) = arctanh(2x - 1), with the latter being confirmed as a valid one-to-one function that maps the endpoints correctly to negative and positive infinity. Additionally, the second part of the problem involves finding a bijection from [a, b] to R, which can be achieved by transforming the interval and applying the arctanh function. The conversation emphasizes the need for functions that maintain the properties of bijections across specified intervals.
rosh300
Find a Bijection \left( 0,1 \right) \rightarrow R
Detention of bijection
let r be a number in the interval \left[ 0,1 \right]
r = a b1c1b2c2 ... bncn where a, b,c are digits between [0, 9]
f(r) =
{ - b1b2b3 ... bn . c1 c2 ... cn if a<5
{+ b1b2b3 ... bn . c1 c2 ... cn if a>=5
i know its incorrect as it is not injective. any help in trying to get the plus minus part.
Another problem with your function is that not every number in [0, 1] can be written that way!
You need a one-to-one function that maps 0 into negative infinity and 1 into positive infinity.
You might consider something like 1/(x-1)- 1/x.
thank u for ur reply and understand how it will work.
would : f(x) = 1/(2x-1) work
as if x < 1/2 it will be -ve and if x > 1/2 it will be +ve
as x --> 1/2 form 0 it will go to -ve infinity
as x --> 1/2 form 1 it will go to +ve infinity
or f(x) = arctanh(2x - 1)
which will transform the arctanh(x) from the (-1, 1) interval to (0, 1) interval as required, and is a 1 to 1 and as you said a function that maps 0 into negative infinity and 1 into positive infinity is needed
1/(2x-1) isn't onto. For example, it's never 0. The second example works fine.
thank you for reply
just for completeness the second part of the question was to: Find a Bijection [a,b] --> R where a, b are real numbers and b > a
this can easily be done by modifying the second example as shown:
let g(x) = x /(b-a) (to transform it into the inteval (0,1) )
and f(x) = arctanh(2x - 1) (the first example)
and have the final function as: f o g(x) ( f(g(x)) )
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
9K
14K
13K
14K
