MHB Find "a" which is a real number
  • Thread starter Thread starter anemone
The discussion revolves around finding the real number $a$ that satisfies the equation $a-\sqrt{4-a}\sqrt{5-a}=\sqrt{5-a}\sqrt{6-a}+\sqrt{6-a}\sqrt{4-a}$. A solution approach involves substituting $m = (6-a) + (4-a) = 10 - 2a$, which simplifies the equation significantly. By letting $\sqrt{\frac{m}{2}} = k$, the equation is transformed and solved for $k^2$. Ultimately, the value of $a$ is determined to be $\frac{431}{120}$. The method demonstrates effective algebraic manipulation and factorization techniques.
anemone
MHB
POTW Director
$a$ is a real number that satisfies the equation $a-\sqrt{4-a}\sqrt{5-a}=\sqrt{5-a}\sqrt{6-a}+\sqrt{6-a}\sqrt{4-a}$.
Find $a$.
Mathematics news on Phys.org
Re: Find a
Find $a$.
My solution
Moving everything to one side of the equal sign, the expression can be factored as
$\left(\sqrt{4-a} + \sqrt{5-a}\right)\left(5\sqrt{4-a} - 4\sqrt{5-a} + \sqrt{6-a}\right) = 0.$
Cleary the first term cannot be zero so the second must. Re-arranging such that
$5\sqrt{4-a} + \sqrt{6-a} = 4\sqrt{5-a}$
and squaring both sides and isolating the square root term gives
$10\sqrt{4-a}\sqrt{6-a} = 10a - 26$
and squaring each side again and isolating $a$ give
$a = \dfrac{431}{120} = 3.591\dot{6}$
Re: Find a
Jester said:
My solution
Well done, Jester! My hat is off to you for thinking out such a nice way to factorize the given expression! (Clapping)
Re: Find a
Find $a$.
My solution:
I first let $m=(6-a)+(4-a)=10-2a=2(5-a)$, this gives
[TABLE="class: grid, width: 500"]
[TR]
[TD]$5-a=\dfrac{m}{2}$[/TD]
[TD]$4-a=\dfrac{m}{2}-1$[/TD]
[TD]$6-a=\dfrac{m}{2}+1$[/TD]
[/TR]
[/TABLE]
So the given equation becomes
$5-\dfrac{m}{2}-\sqrt{\dfrac{m}{2}-1}\sqrt{\dfrac{m}{2}}=\sqrt{ \dfrac{m}{2}}\sqrt{\dfrac{m}{2}+1}+\sqrt{\dfrac{m}{2}+1}\sqrt{\dfrac{m}{2}-1}$
$5-\dfrac{m}{2}=\sqrt{ \dfrac{m}{2}}\left(\sqrt{\dfrac{m}{2}+1}+\sqrt{ \dfrac{m}{2}-1} \right)+\sqrt{\dfrac{m}{2}+1}\sqrt{\dfrac{m}{2}-1}$
I then let $\sqrt{\dfrac{m}{2}}=k$ so I get
$5-k^2=k\left(\sqrt{k^2+1}+\sqrt{k^2-1} \right)+\sqrt{(k^2+1)(k^2-1)}$
Expanding and simplifying the equation and solving it for $k^2$ we get
$5-k^2-\sqrt{k^4-1}=k\left(\sqrt{k^2+1}+\sqrt{k^2-1} \right)$
$25-10k^2+k^4+k^4-1-2(5-k^2)\sqrt{k^4-1}=k^2\left(k^2+1+k^2-1+2\sqrt{k^2+1}\sqrt{k^2-1} \right)$
$25-10k^2+k^4+k^4-1-10\sqrt{k^4-1}+2k^2\sqrt{k^4-1}=k^2\left(2k^2+2\sqrt{k^4-1} \right)$
$25-10k^2+2k^4-1-10\sqrt{k^4-1}+2k^2\sqrt{k^4-1}=2k^4+2k^2\sqrt{k^4-1}$
$24-10k^2-10\sqrt{k^4-1}=0$
$k^2=\dfrac{169}{120}$
and therefore $\dfrac{m}{2}=k^2=\dfrac{169}{120}$ hence, $a=\dfrac{10-m}{2}=\dfrac{10-2(\dfrac{169}{120})}{2}=\dfrac{431}{120}$.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
