MHB What are the Values of k that Satisfy the Given Equation?
  • Thread starter Thread starter anemone
anemone
MHB
POTW Director
Find all numbers of $k$ such that the equation $|x+|x|+k|+|x-|x|-k|=2$ has exactly three solutions.
Mathematics news on Phys.org
Hint:
What would happen to the given equation when we replace $x$ by $-x$?
k=-1 is the only one, 2 is the result for x={-1,0,1}
Thanks, RLBrown for giving us the correct end result for this challenge!:)
Solution of other:
If $x$ is a solution to the given equation, then $-x$ is also a solution, since
$|(-x)+|-x|+k|+|(-x)-|-x|-k|=2$
$|-x+|x|+k|+|-[x+|x|+k]|=2$
$|-[x-|x|-k]|+|x+|x|+k|=2$
$|x-|x|-k|+|x+|x|+k|=2$ which is the same as the original equation $|x+|x|+k|+|x-|x|-k|=2$.
Thus, in order for the equation to have an odd number of solutions, it is clear that $x=0$ must be one of these.
Substituting $x=0$ into the equation, we see that
$|k|+|-k|=2$
$|k|+|k|=2$
$2|k|=2$
$k|=\pm 1$
[TABLE="class: grid, width: 680"]
[TR]
[TD]If $k=1$ and $x\ge 0$, then the equation becomes
$|2x+1|+1=2$ and so $x=0$
But $-x$ is a solution iff $x$ is, so there is only one solution in this case.[/TD]
[TD]If $k=-1$ and $x\ge 0$, then the equation becomes
$|2x-1|+1=2$ and so $x=0,\,1$
Thus, in this case, we have three solutions where $x=-1,\,0,\,1$
[/TD]
[/TR]
[/TABLE]
$\therefore k=-1$ is the unique number for which the equation has exactly three solutions.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
