Find Derivative of f(z) Where z = a+ib
  • Thread starter Thread starter 8daysAweek
    Complex
The discussion focuses on finding the derivative of the complex function f(z) defined as f(z) = { z^2 sin(1/|z^2|) for z ≠ 0, 0 for z = 0. Participants explore the application of the Cauchy-Riemann equations and the challenges of calculating partial derivatives at the origin. The conversation highlights the need for clarity in using expressions like |z^2| and emphasizes the importance of understanding the definition of derivatives in complex analysis. The real-valued function method is mentioned as a counterexample for analyzing the function's behavior.
  • Understanding of complex functions and derivatives
  • Familiarity with Cauchy-Riemann equations
  • Knowledge of partial derivatives in multivariable calculus
  • Experience with WolframAlpha for symbolic computation
  • Study the Cauchy-Riemann equations in detail
  • Learn about the definition of complex derivatives at singular points
  • Research the real-valued function method as a counterexample in complex analysis
  • Explore advanced techniques for calculating derivatives of complex functions using software tools
Mathematicians, students of complex analysis, and anyone interested in understanding the intricacies of differentiating complex functions.
8daysAweek
Find all points where the function has a derivative. At which of these points the function is analytical.[tex] <br /> f(z) = \left\{<br /> \begin{array}{ll}<br /> {z^2}sin(\frac{1}{|z^2|}) & z \neq 0 \\<br /> 0 & z = 0}<br /> \end{array}<br /> \right.<br /> [/tex]
I have tried deriving directly using the limit and also tried using Cauchy-Riemann, both tries led to complicated formulas.
For example Cauchy-Riemann approach:
[tex] f(a+ib) = \underbrace{ (a^2-b^2)sin(1/\sqrt{a^2+b^2})}_{u} +<br /> i\underbrace{{2ab}\cdot{sin(1/\sqrt{a^2+b^2})}}_{v}[/tex]
Now I need to calculate dv/da ,du/da ,dv/db,du/db, but this seems like a headache.
Why do you have square roots over the a^2 + b^2 expressions? Isn't there a |z^2| = |z|^2 = a^2 + b^2 term in the original function?
Also taking partial derivatives is easy. Just check the Cauchy-Riemann equations for z = a + ib =/= 0. At the origin, you'll probably have to resort to the definition anyways. You might already know the answer at least for the origin since there is a real-valued function that is similarly defined and often used as a counterexample.
Yes, my mistake, it should be a^2+b^2 without the root.
But, still it does not make finding partial derivatives simple. For example, here is du/da calculated by WolframAlpha:
Can you explain the real-valued function method? How do you use it as a counter example?
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 27 ·
  • · Replies 22 ·
